Question about Intellinet Active Networking Intellinet Wireless Router with 4 Port Switch (521246)
INTELLINET ROUTER I have an intellinet router and all the computers feed of them.I just got a DEll with a lynx adapter and the computer will not pickup on it.I also viewed wireless connections and it is blank.
PCBuilda
  • 101 Answers
SOURCE: router & new laptop
Firstly you need to hard wire your internet line to your router and then your router to your pc. You cant really set it up unless they are "connected" physically. You need the SSID information and if you are going to be secure you need to set up a secret key/password key/secret phrase that each computer will have to have in order for the two devices to do the handshake and understand each other. Your security should be WEP, WPA, WPA2. Once hard wired you need to start an internet session and put the IP address of the router management console into your browser ie http://192.168.0.1 (refer to your manual for this and the admin password needed to access the console) Once in here you set your security type WEP etc and your secret key. (Think of this as your password/passphrase) On your pc you need to set your wireless networking device to have the same information. Then you can work wirelessly as long as all devices have the same information. There is no substitute for reading the book for this one though.
Posted on Mar 07, 2008
  • 65 Answers
SOURCE: New topic about Intellinet Active...
You have a switch which is like a hub. You want a router, the router will assign IP addresses to each computer in your home. If you need to set up port forwarding then you do that within the router settings. For the most part newer routers have Universal plug and play which will handle the port forwarding for you.
Posted on Jun 01, 2008
  • 92 Answers
SOURCE: Intellinet Active Networking IP
192.168.10.1 works on mine
Posted on Jun 17, 2008
  • 630 Answers
SOURCE: how do i secure my connection with an 523431
I presume that you are trying to connect wrelessly. You need to select the same type of security at both the router and the computer. WPA is the most secure so select that. It is easier to do the router setup using a wired connnection. Then disconnect the wired connection and then right click on the adaptor on the laptop and setup using the same configuartion etc.
Posted on Jul 06, 2009
SOURCE: I just purchased a Dell Latitude 6500 laptop and I
hi! there is no problem with your internet connection with your router but the problem is your dell lattitude wont connect to the wireless network, please try to disable your dell software for connecting to wireless network and just use the windows wireless zero config, check the on the taskbar on the lower right of the monitor, there is an icon for the wireless connection for dell, right click it and select disable, sometime there is an option that windows will ask if you want to turn on the wireless zero config..if it didnt ask, click onn start, run and type in service.msc then it will show the services go to the buttom portion and enable the wireless zero config..
Posted on Aug 09, 2009
I need intellinet wifi password
Follow this link and you will get the manual for intellinet router and it will be easy for you to see your wifi security password.
http://www.retrevo.com/samples/Intellinet-Router-manuals.html
Mar 07, 2011 | Intellinet Active Networking Intellinet...
Am asking for the default ip address for the router
You will get the default IP address for the router by following the instructions below.
1. Go to command prompt.
2. Type ipconfig and hit enter.
3. The address mentioned next to Default gateway is your Router IP address.
Note: Make sure that the router is connected to the computer using the Ethernet cable.
Nov 16, 2010 | Intellinet Active Networking Intellinet...
Hello. i am trying to use my intellinet wireless 300n adaptor, but have the wrong password. how can i access the password?
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Jul 06, 2010 | Intellinet Active Networking Intellinet...
Bought a wireless router-intellinet 150n4-port router. i had cable internet hooked by modem to my desk top. i dont have a clue how to set this up. wanted the wireless for the wii game up stairs. hooking it...
http://www.intellinet-network.com/en-US
link above for manual find exact model 7 number & download, read up.
You hook up with an Ethernet cable, you type in the "Address" of the router, in manual, login, using default name and password, in manual, once logged in toy can then run the "Wizard" this will help you connect. You need to know your Internet Account login and password. Once all setup you save and now you can use it. it is all explained in the manual. It is a few pages so it was not possible to post here.
Mar 26, 2010 | Intellinet Active Networking Intellinet...
I NEED AWEP NOR AWPA FOR MY INTELLINET WIRELESS G
Get into the configuration mode of the router by using your browser and type 192.168.1.1.
Give your username & pwd(usually ...admin/admin) and then go to wireles security tab and select WEP or WPA.
Oct 19, 2009 | Intellinet Active Networking Intellinet...
Router
maybe ip address change/.. check the ip of ur router
Aug 24, 2009 | Intellinet Active Networking Intellinet...
May 31, 2008 | Intellinet Active Networking Intellinet...
Intellinet Active Networking Intellinet Wireless Router with 4 Port Switch (521246) Logo
199 people viewed this question
Top Intellinet Active Networking Computers & Internet Experts
Prashant M
Prashant M
Tech support
Tech support
Are you an Intellinet Active Networking Computer and Internet Expert? Answer questions, earn points and help others
