Getting VCR to record from Bell Express View
We just got Bell Express View Satellite T.V. and would like to use our VCR with the set up. The Bell Express View system is asking us for a 3 digit manufacturer's code. We have looked everywhere on the VCR but cannot find a 3 digit number to put into the system. Therefore, we cannot get our satellite T.V. hooked up to the VCR. Does anyone know what the 3 digit manufacturer's code for the Panasonic PV-7401 is????? MODEL # SLV-N60
Try this website
http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-Old.doc
keep scrolling down in the list until you find the vcr codes.
i found the 3 digit code for my sony VCR. it gave me several codes, but i finally found the one that worked with my bell expressvu.
good luck
Posted on Feb 19, 2009
Set up VCR for recording with Satellite TV
You will not be able to record satellite (digital signal) onto a VCR (analog signal) without what is called a scan converter. This is the only way to do it with your current machine. It can be done but the cost of doing it properly will come close to using a different recording method.
Aug 30, 2014 | Televison & Video
Recording from Sky
you need to connect the satellite box directly to the VCR and record
Sep 09, 2008 | Televison & Video
I have a THS220 box and have difficulty recording programmes
Hello Joan,
To record a satellite you will need two scart leads.
Plug one end of the first scart lead into the "DVD/VCR SCART" socket on the back of the satellite receiver, then plug the other end into the "INPUT" scart on the back of the VCR. Take one end of the second scart lead and plug it into the "OUTPUT" socket on the back of the VCR and plug the other end into "SCART IN" socket on the back of the TV.
To record, select the satellite channel you want to record, then, on the VCR, select scart input, (at this point, you can record a satellite program). To watch a satellite channel or recorded satellite channel, select the scart input on the TV.
If you need anymore information, then let me know.
Kind regards,
Ron.
May 04, 2014 | Thomson Audio Players & Recorders
How to hookup vcr to TV to tape from satelitte
have a look at ur install bock it will tell u how to do it...connect antenna to ur vcr then use cable from ur vcr output to ur tv antenna ,,,,,after u have done this read instruction .....to connect ur dvd ....just plug ur cables from ur dvd to the back or ur tv....marked as dvd input....
cheers and good luck......very simple.....
Mar 06, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
Magnavox DV220MW won't record.
You need to plug a red, white, and yellow cord from the red, white, and yellow OUT of your cable or satellite box into the red, white, and yellow labelled VCR IN/LINE 1 on the Philips. To view what you are trying to record, make sure there is another red, white, and yellow cable plugged from the DVD/VCR OUT of the Philips to your television. Make sure the television is on the appropriate source channel (AUX 1, AUX 2, VIDEO 1, VIDEO 2, etc). Then press the VCR button on the Philips. You should now see your cable or sat channel (as long as it's not an HD Satellite box) on the television screen. Press record, and you are on your way. Good luck!
-Tha Mp3 Doctor
Dec 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Sanyo VCR
get a 2 A/V cords (yellow, white, and red plugs). Plug between the Satellites "video out" jacks and the VCR's "input" jacks. Connect the second cords between the VCR's "video out" jacks and the TV's "video in" jacks. Make sure the VCR is set to the input that you plugged the satellite cords into and make sure the TV is set to the input that you plugged the VCR's cords into.
And then you're done. To record, set satellite to channel desired, set VCR to record on the video input (instead of a channel number) and you're good to go.
Sep 08, 2008 | Sanyo VWM-800 VHS VCR
Connecting to a Satellite reciver
I solved the problem with my DVD recorder. I attached a cable from the loop out on the back of the FTA receiver to the RF in on the back of the recorder. All I was missing was the signal from the satellite. Everything is working fine now.
Thanks
JimCee
Mar 23, 2008 | LG Televison & Video
Toshiba DVD/VCR Recorder
The only thing you can do is to program the recorder to come on and record at a certain time and also program the event timer for the Bell Expressvu.
Mar 13, 2008 | Televison & Video
Not enough channels
The history of broadcasting is one of adding more and more channels. The older the VCR, the less cable channels it will get.
Jan 01, 2008 | Toshiba W522 VHS VCR
Vcr timed recordings
I'd be pretty certain that every VCR made these days (and of the last 10-15+ years) can be set to do a timed recording. They can be set for a one time recording, weekly or daily record. Whether used with a cable/satellite box, or outside antenna, you must ensure proper hookup. I'm not real familiar with recent cable/sat receiver boxes, but older ones had to be set to the channel you wanted to record, as the VCR will only see that channel. On older cable (no cable box) & outdoor antenna systems, a VCR could tune in and record any channel, while you watched another one. Anyway, check the capability of the cable/sat box, and follow suggested hookup. You will likely need to set the box to the channel you want to record before you retire for the night.
Sep 26, 2007 | Televison & Video
Televison & Video Logo
500 people viewed this question
Top Televison & Video Experts
