Question about Apple HP Officejet G85xi InkJet Printer
Hp g85 cartridge jam
Can not get cartridge jam clear
  • luckyduck60 Feb 17, 2009
    i have the same problem. cartridge jammed. does not work after i follow scrolling instructions.
Officejet G85
For the paper jam you remove the back cover and clean the 4 rubber rollers with alcohol, you can rotate the rollers forward while you clean. For carriage jam you start by cleaning the encoder strip that runs across behind the carriage unit, the clear strip with black bars on it, you can wipe with a Q-tip damp with alcohol. If no help you may need to take apart and clean dried ink off of the service station on the right.
Feb 01, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
SIR PRINTER SCREEN SHOWING DOOR OPNE, CLEAR
sir printer screen showing door open, clear cartrdge jam and then press enter
Jan 18, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
Paper Jam - HP G85 Ink Jet Printer
You open the door from the back of the printer (turn the knobs) and the paper can be removed from the back. After removing paper jam, replace the door. It is a long door as wide and the printer, but about 2 1/2" wide.
Feb 28, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Color ink cartridge HP Officejet G85
clean the copper contacts with soft cloth...
Feb 25, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
My HP DeskJet g85 says "cartridge alignment has failed"
Here is the weblink which helps you in resolving cartridge alignment failure issue:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&cc=us&lc=en&dlc=en&product=60399
Click on the link above and follow all the steps give in web document.
Thank you.
Dec 06, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Cartridge
Easy! Just open the front latch by lifting up, unlock the cartridge you are replacing, and snap in a new one. I caution you to use only HP new cartridges for best results. You can find a pretty decent price on them at www.amazon.com. Also, reset your ink counter in the HP Image Zone to reflect the new cartridge install. Then run the align cartridges option and you're all set. Hope that helps. If so, please rate this solution. Thanks!
Sep 13, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Apple HP Officejet G85xi InkJet Printer Logo
138 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Don  Farrell
Don Farrell
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
