I am running it on windows platform
Right click in your drive select new folder and name it Place all data files you want to password protect inside your new folder Right click on your new folder select properties select the sharing tab Scroll to network and sharing at the bottom You have many options to password protect many files and folders Windows 7 In XP right click on your folder select properties then click the sharing tab tick the box do you want to make this folder private A message might appear if you have a password do you want to create a password Or you might download one or more of these all are free password protection programs b> http://download.cnet.com/truecrypt/3000-2092_4-10527243.html True Crypt Free Encrypt your sensitive data with this open-source software. http://www.truecrypt.org/ for more information on this software b> http://download.cnet.com/folder-lock/3000-2092_4-10063343.html 25 MB http://download.cnet.com/truecrypt/3000-2092_4-10527243.html http://download.cnet.com/my-lockbox/3000-2144_4-10789387.html Hope this helps.
SOURCE: Maxtor Basics 1Tb external hard drive not working
Apri il prompt dei comandi e digita cd.. e premi enter tante volte quante servono per andare in C:> ; ora digita CHKDSK X: \F dove X: dovrai sostituirlo con la lettera assegnata all'HD in cui non riesci ad entrare, premi enter. In poco tempo corregge gli errori, non si sa (almeno io) come si sono formati, e tornerai a riveder le stelle! Te lko auguro ame ha funzionato
option 01. try the unit on another windows pc. if its the same. i am afraid you might have an issue with the device.
option 2 . you could remover the **** from the enclosure & fix it directly to the pc so that you can retrive the data. however this will have an impact on your warranty
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
SOURCE: 1tb Verbatim External Hard Troubleshoot
does it work on another pc ok? Do other usb devices work ok? Give me the details and I can help you solve this.
Paul
SOURCE: Forgot Acomdata External Hard Drive Password
Did you every get this resolved? I have same probelm.
Hope this helps
