Question about Sony KV-20M42 20" TV
Possible to connect rabbit ears with prongs to Toshiba 27A43C ?
Moved in 2 weeks ago. I've had 2 Satellite installers refuse to install Dish due to the number of trees on our property. They claim they won't be able to get a clear signal. So I phoned the Cable company because there are cable outlets in two rooms? But the installer arrived today and there is no cable to the house for whatever reason, we don't know? They had to reschedule the appointment until they can send two techs to string the line. 72 hours if I'm lucky.
Meanwhile, I noticed some of the posts on here dealing with Rabbit Ears and newer TV's?
I have Rabbit Ears but they have the prong type connections that slid under a screw and were tightened down.
My question is, can they be connected to a newer style TV with (jack?) plugs.
If so, How do I do this??
  • countrycasua Jan 29, 2009
    Clark, Thanks for your prompt response and the Quick Fix. I'll do that tomorrow morning.
    Can't get much simpler than that. :)
    I only need them to work for a few days. And here in Canada, television is being switched to digital but not until 2010, so there's not the same urgency as folks here in the U.S.
    I appreciate your feedback. TY
  • 40 Answers
Your rabit ears will sadly only work for about 2 weeks though! its not quite worth the cost as the new law in the states is making rabit ears useless.
Posted on Jan 29, 2009
  • 360 Answers
Yes, it can be done, make a quick trip to radio shack to get the adapter you need.
please take the time to rate this solution.
Dish satellite diplexer issue
Partial solution: I have had rabbit ears sitting on my roof, somewhat tied in with my dish, for close to two years. It's just a matter of running a coax out.
Sep 01, 2012 | DISH Network ViP722 DTV Receiver /...
Weak signal
Please, start thinking of "outdoor" HDTV antenna installation. You must of be in use of TV's SD tuner and "rabbit ears" or so. Only outdoor or "roof" antenna will solve your issue. Unless you have another option: satellite, cable, verizon? Check with them, first.
Need antenna?
Call Alex's Television.
Nov 29, 2011 | Toshiba 26AV502R 26 in. LCD HDTV
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
I have an 8 inch wide yellow vertical band in the picture of my 52 inch LCD Samsung TV, what is this? I just moved into my new house a couple of weeks ago and purchased a new 52 inch TV, We are without...
If the band is there within the menu then the screen has a fault. If not then possible signal ghosting issues and a proper aerial should fix that.
Jun 30, 2017 | Televison & Video
Good afternoon, Ihave a viewsonic va702 17" monitor and would like to use as a receiver monitor for sky in my motorhome, is this possible and what would i require. regards Rosco
The ultimate would be a satellite dish. Also, If you know where the broadcast stations are near-by then you can get a small outside or rabbit ear antenna along with the hd converter box that has RCA jacks for video output then your all set to go.
Oct 09, 2009 | ViewSonic N4280P TV
Toshiba Tv - Does it have a digital tuner?
That unit has a NTSC tuner. May be HD Ready but it does not have a digital tuner. Unless you live quiet close to a local Broadcaster, rabbit ears would be useless.
The only way you would be able to get HD is using a HD Set Top Box, HD Satellite System,
or HD Cable BOX, using the Componet or HDMI inputs.
Hope this helps
Jun 22, 2009 | Televison & Video
Toshiba Laptop A 105 missing winsoc 2
I recommend you restore your computer using the system recovery application. Hopefully you have a back-up for your other files. This is the only sure way to restore your system back to factory setting and restore your missing files. Good Luck.
Feb 03, 2009 | Toshiba Satellite A105 Notebook
How do I hook up my Dish Satelite to it?
should go from your satellite to dish box might say sat on bck of box then the next [connection think says tv that should go to tv itsself or dvd vcr whatever ur hooking up to it then from that point hook it to ur tv
Oct 23, 2008 | JVC AV-56WP74 56" Rear Projection...
TV won't work with rabbit ears
You must change the input on the system to be AIR/Antenna , the way it was before was set to cable/dish/DTV.
The tv sees the input different.
Jun 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Toshiba CF36G50 Noisy when you turn it on
that sound is comming from the tube anode it is leaking you have to discharge the high voltage from the anode cap,then take off the cap clean the area with alcohol and put some red or clear silicone on the cap and anode connection replace back the cap on the tube leave to dry for about half hour,this will remedy your problem,no more static.good luck.
Jul 05, 2007 | Toshiba CF36G40 36" TV
Sony KV-20M42 20" TV Logo
108 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
