Question about Encore WL ROUTER |ENHWI-SG 54M 11B/G (ENHWISG)
Unable to apply any authentication for the Wireless
Unauthenticated wireless connections work alright. At the 192.168.1.1 > "wireless" > "authentication" admin page, the "apply" button won't have any effect when I chose WEP, WPA or WPA2. (If I change to the "basic" tab and back to the "authentication" tab, I see the changes didn't stick: Authentication Type [disabled]) Tried all sorts of restarts. Tried to disable wireless before setting authentication. Tried firmware update. Tried filling all WEP keys, tried ASCII and HEX, tried 64 and 128 modes. Tried all settings.
    President:
  • 2,961 Answers
There should'nt be a problem setting WEP security or an other unless there is a firmware problem, as you simply select security, then the method e.g. WEP, select hex, then open system amd type manually your values for a chosen key number from 1 to 4.
Posted on Jul 27, 2007
Unable to connect to network
try to call product company and see if you can get authentication number
Jul 31, 2012 | Sony VAIO VGC-LS21N PC Desktop
I have Netgear DG834G v3 working fine on 3 laptops (vista) 2 iPhones ps3 and wii with wep and no issues. I bought a new printer which requires wpa to be used but when I change over nothing will connect....
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 15, 2011 | NetGear DG834G Router
Windows was unable to find a certificate to log you on to the network OS is XP SP2 N614
Here's how to connect to your wireless router if you are getting this message:
First, click on the wireless icon in your taskbar and under Related Tasks, choose Change advanced settings.
Now click on the Wireless Networks tab and select the network in the list at the bottom. Click on Properties once you select the wireless network that is having problems.
Click on the Authentication tab and now uncheck the Enable IEEE 802.1x authentication for this network box. If the box is checked, then that is why you were getting the "unable to find a certificate to log you on to the network" message because Windows is looking for one, but your wireless router is not setup for certificate security.
And that's it! Once unchecking the box and try to reconnect to the wireless network, everything should work fine.
Hope this helps!
Apr 06, 2011 | NetGear WGR614 Wireless Router
I just installed a Motorola SBG6580. I have it connected via Ethernet to my desktop (MS XP) and via wireless to one of my laptops (MS Vista). Both work well. However, I have been unable to connect my...
Try changing the authentication type to WEP/WPA/WPA etc. Might be your XP laptop doesn't support current authentication type. Thanks for joining us. Have a nice day.
Feb 24, 2011 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Attempt to go on wireless and get "need certificate" to continue. Any help for this?
Hi!
Here's the solution to your problem:
1. Go to Control Panel > Network Connections
2. Right-click on Wireless Network Connection > Properties
3. Click on Wireless Networks tab. Remove all the names under Preferred Networks box.
4. Click on Add button. Type the Name or SSID of your wireless network
5. If you have encryption enabled, uncheck the box at the bottom "The Key is Provided for Me Automatically".
6. Type in your wireless encryption key in the given boxes.
7. Now click on Authentication tab. Uncheck the box that has the "Enable IEEE Authentication".
8. Click Apply and OK all the way out. Restart your computer.
9. It should be able to connect wirelesly.
Jul 28, 2009 | Computers & Internet
Lenovo 3000 N500 - unable to connect to Wireless Internet
You need to get the wireless authentication details from the library's front desk to configure your wireless connection. They should be able to help you.
Feb 19, 2009 | Lenovo ThinkPad T61 Notebook
CAN'T CONNECT TO WIRELESS ROUTER WITH LAPTOP.
Temporarily disable all security on the router AND your laptop wireless card and try again to test connectivity.
The exact error message should be:
"Windows was unable to find a certificate to log you
on to the network [SSID]"
This is caused by setting the encryption to WPA-RADIUS instead of WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.
Switch the encryption to WPA-PSK (pre-shared key) on both ends and it should30924e8.jpg work.
Also check to make sure that IEEE 802.1x authentication on the wireless network properties Authentication tab is disabled.
Jan 04, 2009 | Linksys WRT160N Wireless Router
Wireless network connection windows was unable to find a certificate to log you onto network
xp : go to start --> control panel ---> on the top leff click on "switch to classic view" then open network and internet connections right click on the wireless conn. then from the upper tabs go to "Authentication"  your setting should be as following :
Enable IEEE 802.1x ....... (cheked) EAP Type : Smart Card or certificate Authenticate as computer ...... (checked) Authenticate as gues ..............(unchecked)
then click on "properties"
choose "use a certificate on this computer" and check "use simple caertificate ......" and check "Validate server certtificate" click ok till u close all the boxes
:D hope that would work :D
Oct 17, 2008 | Computers & Internet
Trouble reconfiguring WGR614 v5 after reset
Dear Koteshst
Is it the router that's showing 'Limitted and no connectivity' or the PC trying to connect to the router? If it's the latter make sure that the router is configured to assign IP addresses via DHCP and that your WEP/WPA keys match on both sides. If it's the former check your authentication info for SBC.
Let me know.
J
Feb 24, 2008 | NetGear WGR614 Wireless Router
Suggest resetting to factory defaults, then see if your can make changes to the authentication's. If not go the website of device and access help and support. BPCS
Dec 14, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
299 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
