Question about KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels
Kitchenaid stand alone ice maker. Fills resevoir with water and begin to make ice. When the resevoir is empty, the unit doesn't know to let water in again and the pump just cavitates away
  • Anonymous Mar 10, 2009
    Yes I cleaned the plate as per Kitchenaid. I removed all the guts so I could get to the plate easily. I scrubbed the plate with a nylon scrubee and nickle free cleaner. The ice maker worked well for about a month. Last night I heard the sucking sound from the pump and knew that an ice sheet was stuck. It was. I dragged it off the cooler plate and things seem to be ok for now. Is there a better way to really clean that plate? By the way, we have very good low scale water.
  • May 11, 2010
    hi my name is mark, has this unit been cleaned, is there scale on the plate where the ice is made.
    Guru:
  • 462 Answers
Check and see if your cutting grid is still lined up on the back side towards the freezer plate. I have had the cutter miss align on some and failed to see it then just have to remove the thumb screws and re set the back end. Feel for more roughness from scale. Especially on the sides and edges. you may need to clean it again
This unit I believe is set to allow water in when it goes through a harvest. it wont refill until the coldest temp is reached then will stop filling after the warmest temp is reached.
Posted on Mar 12, 2009
I have a whirlpool gold stand alone ice maker (GI15NDXXS) that isn't getting water.
It sounds like a stuck water valve. I am providing a link to a website that has tons of information on these units in general. Use it as you see fit. Repairing the Whirlpool and KitchenAid Ice Machines
Jun 10, 2017 | Whirlpool Refrigerators
How long once the ice maker starts making ice should we use it
What kind of ice maker is it? Is it a stand alone or is it inside your freezer? If inside your freezer it will take two days to fill the storage container. Stand alone types usually make 20 lbs of ice in 24 hrs or so.
Jul 17, 2014 | Kitchen Appliances - Others
My stand alone kitchen aid icemaker is filling up with water. It is making ice but it keeps filling up with water as well. I had a plumber come out last week because the ice maker was leaking. He fixed...
The drains on items like this get a sludgy residue built up in the drains. Make sure its clear. Empty the bin and you should see the drain port run a small amount of hot water in it. Not a lot as it could leak from the drain tray if it has one. If the drain is clear then it could be a nice maker issue where it's dumping too much water in the tray to harvest. Excess would spill over.
Sep 26, 2013 | KitchenAid KUIS18NNT 18" Automatic Ice...
Kitchenaid stand alone ice maker makes ice and melts all the ice
Is it melting through heat or spilling water onto the ice already made? I suspect the latter, in which case suspect a blocked overflow drain
May 01, 2012 | KitchenAid Refrigerators
Kitchenaid stand alone ice maker not producing ice. Water fills into the resevoir but do not see water flowing on to the ice pan. water drains from the tub fine when called for and fills back up. Was...
most likely the recirculating pump is jammed or has failed... ive been in service industry for 18 years and actually have a kitchen aid stainless steel ice machine myself.... if you get into unit and remove the resorvoir and white plastic shield around pump which is located on right side normally.. then there is 3 1/4 inch screws to remove from the pump and the water line usually attached on side of pump plate just unsnap... unplug the molex plug and pull out... you can check impellar for scaling and or build up turn with hand.. if you think you free it up clean real well and test with a power cord while out. you will have to rig something to the molex plug and plug into a 110 outlet and test... if it is bad get you a new one and replace.... this is a common problem ...good luck to you
Jan 08, 2011 | KitchenAid Kitchen Appliances - Others
Ice Maker won't work
If your trying to save a service call you have your work cut out for you. The ice maker is a unit that sits by itself attached to the wall or part of the freezer wall.
There are many reasons why you do not get ice and I will list them.
1- Temp of freezer got too cold and has frozen the pipe that feeds the water to fill the icemaker.
check to see if the icemaker has any ice in the area that fills and makes the cubes.
If the pipe is clogged, very gently put a small tipped screw driver in the fill hose that sites over the ice making row in the ice maker. Be careful you do not push your screwdriver out the back of the refer.
Check to see the freezer temp is not too cold and is freezing that pipe. 0-3 degrees F is good.
2.- check to make sure your water feeding the fridge is on. There is an on off valve to allow the water to feed the icemaker when it needs to fill. This could be bad. there are reset proceedures for the fridge, but unplugging the entire frige for 1 minute and plugging it back in you can listen for the the valve to come on and see if it fills the ice maker resevoir.
3. If it fills and freezes the ice resevoir, then the sensor in the ice tray does not sense the frozen ice and will not cycle and kick cubes. At this point, unless you are super tech, you will need to replace the entire icemaker unit.
Hope this helps.
Mar 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Kitchenaid stand alone ice does not make ice feel heat inside bin
Either has electric problem or mechanical.
way to tell is plug it up, turn it on turn on water. If its sending in water unplug it and if water stops it is electrical and the ice maker head is causing the problem if it stops the water valve is stuck open and you can disassemble and clean it out sometimes. A slight lime scale can cause this.
Hope this helps please rate me accordingly and good luck.
Mar 12, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Stand Alone ice maker leak
Your model number must be plumbed to a external drain.
You may have to install a condensation pump to do this.
Mar 10, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
Jan 02, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels Logo
1,902 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
