Question about Pinnacle Studio Ultimate 12 for PC
Flicker on dvd
I have been using pinnacle studio 12 for pc and making home movies. When I go into the make movie command and create a dvd disc on the dvd some of the clips flicker like another scene is superimposed for a second on top of another one, but if you play the same clip in the editing mode they don't flicker at all. I am using vista if that helps. I really like this program but I am frustrated and I am wasting a lot of dvds. Please help
    New Friend:
Well I am having the same problem
My pc crashed so it was re built
installed windows 7 same problem
then went back to XP same problem
I reinstalled pinnacle 12 ultimate BUT can not down load the the patch via the net its not avaible now
We need to get this patch
Sunjith sewsunker
Posted on Jul 15, 2013
4 Suggested Answers
SOURCE:
hawkform
  • 217 Answers
SOURCE: pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
Posted on Feb 17, 2010
hawkform
  • 217 Answers
SOURCE: I can't make a 16 minutes movie on my Pinnacle
Hi and Welcome,
Click on the completed project in the timeline, go up to "Edit," click on "select all" in the dropdown menu, then RIGHT click anywhere in the now-highlighted project and select "Copy."
Now go back up to "file" and click on "New Project." Your current timeline will close (don't worry. It's saved,) and a new blank timeline will open. Left click anywhere in the new timeline, then right click and select "paste."
After a terrifying period when you think nothing is happening, your entire project will suddenly appear in the new timeline.
Save it with a new name, then try rendering again.
Posted on Nov 18, 2010
hawkform
  • 217 Answers
SOURCE: I can't make movie or
Hi and Welcome,
Click on set up>video and audio preferences>unchecked background rendering>click on "used this codec for background rendering>click and choose MPEG2 for best output to disc. Now click on project preferences>click on delete button and then choose delete auxiliary files for all project and then click okay.
Try that one and let me know what happen.
Regards,
Pinnacle studio ultimate 12
Does the player you are using for playback support the file format you saved it in? If not you will need a codec to view it.
Sep 02, 2014 | Pinnacle Studio Version 12 for PC
I can not play my dvd on sony dvd player i get message canot play.i have a sony dvd recorder in which my laproscopic surgeries are recorded.if i play my unedited dvd on player it runs or plays very well...
My guess is the Pinnacle software isn't writing correctly. Read this from the Pinnacle support site.
Use this FAQ to troubleshoot any problems where Studio is failing during the process of burning the DVD.
  1. INSTALL THE LASTEST PATCH:
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
Note: Studio 11 patches will only patch a previous install of Studio 11.
If you have an older version of Studio (Studio 9, 10, or 11 etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
  1. MAKE DISC SETTING, SAFE MODE BURN OPTION: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Safe Mode: create disc content and then burn" by clicking on the radio button in front of the setting and then click OK. While troubleshooting this problem, always use this setting.
  1. RESTART STUDIO: Shut down Studio, then relaunch it. Try to create the DVD again using the safe mode setting above.
  1. RESTART THE COMPUTER: Try opening the door of the DVD burner. If it won't open, then shut down Studio, then restart the computer. Launch Studio and try to create the DVD again using the safe mode setting.
  1. MEDIA:
BLANK MEDIA IN THE DRIVE: Make sure that there is a blank, write-once media or rewriteable media in the DVD burner.
TYPE OF DVD: Make sure that your DVD burner supports the media you use. As for any problem with burning a DVD, we recommend customer use rewriteable media to reduce the number of wasted DVDs when they have to troubleshoot a failure while burning DVDs. In this case, if you have only used rewriteable media, (RW) we would also recommend trying to use a write once (-/+ R) DVD and erasing the RW media.
BRAND OF DVD: Pinnacle recommends using a name brand of DVD, i.e. Sony, Apple, Memorex, etc. Also we recommend trying a DVD from a different manufacturer to see if the problem is related to the brand of DVD that is being used.
NOTE: Check with the following site to find information on the media being used.
http://www.videohelp.com/dvdmedia
  1. LOWER THE WRITE SPEED: In the Make Disc settings try lowering the Write Speed to the lowest possible setting.
  1. GET THE LATEST FIRMWARE: Ensure that the DVD burner being used has the latest firmware update from the burner manufacturer.
  1. CHECK DISC SPEED: Make sure that the disc media speed (printed on the media or on the media box) is compatible with the DVD burner. Some burners may not work with media that has a higher maximum supported burn speed. For example, if the burner being used supports 4x disc media, do not use 16x disc media.
  1. DELETE AUXILIARY FILES: Try deleting the Auxiliary Files for the current project. To do this, go to File -> Delete Auxiliary Files and select "Delete auxiliary files for current project." Press OK and try to re-render and burn the project.
  1. ALWAYS RE-ENCODE: Go to the Make Disc settings and check the box called "Always re-encode entire movie".
  1. SAFE MODE: Try burning with the safe mode option selected. To do this, go to the Make Disc settings. In the Burn options are select the option called: "Safe mode: create disc content and then burn.". This step does not apply if you are using Studio 12 since this is the default burn method.
  1. CREATE A DISC IMAGE: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Create disc content but don't burn" by clicking on the radio button in front of the setting and then click OK. Then click the Create disc button in the Make Movie section to begin the image creation process.
    If the image is not created, it is likely that the problem is a Render problem rather than a burn problem. Click Here to see the FAQ on Render problems.
    If the disc image file is created successfully, burn the disc from the new disc image by selecting "Burn from previously created disc content" in Burn Options.
    NOTE: When troubleshooting all burn or playback issues, it is recommended to use rewritable media to avoid wasting discs.
Nov 04, 2010 | Sony DVP-NS530 DVD Player
Export:error:real time c:\users\owner\appdata\local\microsfolder\render\my movie 848e009f\alternate\render\my movie 848e009f\dvd\studiosequence\temp' Help - what does this mean? What should I do?
Hi and Welcome,
If you are experiencing Export Errors using Studio, the following FAQ should help:
1. UPDATE TO THE LATEST PATCH:
Click here for the latest Studio 12 patch
There is no patch available at this time for Studio 14
2. ENSURE BACKGROUND RENDERING COMPLETES:
Allow the green bars that appear over clips that have had filters, transitions or other effects added to complete before going to the Make Movie stage.
3. ALWAYS REINCODE ENTIRE MOVIE
If after installing the latest version of Studio, the Export Error persists and you are attempting to create a DVD, then in Studio click on the Setup pull-down menu and select Make Disc. On the top portion of the Make Disc tab make sure there is a check in the box for the setting "Always re-encode entire movie", then click the OK button. Create the DVD again.
4. DELETE AUXILIARY FILES
Delete the auxiliary files before rendering. To do this, go to File >> Delete Auxiliary Files. This will bring up a window to chose which auxiliary files will be deleted. Select the option to delete the files for the current project. Once this is done, try to output the project.
Oct 12, 2010 | Pinnacle Studio Ultimate 12 for PC
Pinnacle 14 crashes at the same point when making movie.
Hi
My pinacle 14 crashes when I try to make a disc, if I make a disc from other movies i have edited it works just the current project we are working on , I have deleted the Aux files
Cant move
Peter
Apr 28, 2010 | Pinnacle Studio Ultimate 12 for PC
Pinnacle studio 12 .stx fil
Disc Type : DVD
Copies : 1
Feb 14, 2010 | Pinnacle Studio Plus Version 11
When making / creating a DVD, how do you make the "Play" button work, so that the result of your movie you will select the "Play" button and your movie will play. Also how do you create chapters, but allow...
hi there,
you can find the manual here :
Pinnacle Pinnacle Studio Ultimate Version 11
and in other languages please look here :
ftp://ftp.pinnaclesys.de/Manual/Studio%2011/
I suggest to look under the word :
Scene detection ...............26
The Video Scenes section ....... 40
CHAPTER 9: DISC MENUS.... 175
Output to disc media ... 243
Have a nice computing
Hope that helps
IF NOT then try to return here
Please rate my answer
Dec 09, 2009 | Pinnacle Studio Ultimate Version 11
When saving movie to DVD Disc it does not play on DVD machine
you just cant save a movie to a DVD and play them on DVD players....it just does not work that way
you need to write them properly using a software like Nero
Create DVD/CD/Mini DVD etc in Nero is a good option
Nero is a software for audio and video editing and recording.
Dec 06, 2009 | Pinnacle Studio Ultimate 12 for PC
After burning the DVD once,
Several possible solutions.
1. If you are using DVD-R discs, your player probably does not support them. There are known compatibility issues with DVD-R discs. If your burner supports it, use DVD+R discs.
2. Try burning at the slowest possible speed. That can help your player pick up the disc better.
3. Did you remember to put a menu in the beginning of your movie? Even if you have the disc set to skip the menu when inserted, it still must exist for some DVD players to recognize it as a disc and play it.
May 31, 2009 | Pinnacle Systems Studio AV/DV Version 9...
Pinnacle 10 dvd burning
have you tried rendering as an AVI file ... then burning???
also, check the drop down tab to make sure in the "make a disc" section that
there are not 2 listings for the dvd choice ... if there are... then select the second
dvd.. and tell it to burn...
or make the AVI and use Nero 8 or 9 to make the DVD.
my version 10.8 is whacked...
upgraded to 12... it's working fine... finally.
bbell
Dec 14, 2008 | Pinnacle Studio Plus 10 Full Version for...
A DVD burned with Studio 10.8 plays on our stand alone DVD player, but it won't play on our computer.
check what mode the cd video is you may have to burn another one with the correct mode for pc
Right click program on cd go to properties check video name plus what is after the . ie home.wmv as you need to burn cds with a general code
Try VLC Media Player on computer this plays all my video media
Jul 22, 2008 | Pinnacle Systems Studio AV/DV Version 9...
Pinnacle Studio Ultimate 12 for PC Logo
109 people viewed this question
Top Pinnacle Computers & Internet Experts
Peter Dragonetti
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
