Have desa unvented heater (model CGCFTN). Pilot will not light unless I put a match to it. Then the pilot light is abnormally high
  • 10,865 Answers
Based upon your description of the problems it sounds like you have an electroni igniter that is not working. There is a battery in the remote and in the igniter. If either battery is dead it must be replaced to get the electronic ignition.
Posted on Jan 29, 2009
  • Joe Hogan Jan 29, 2009
I have a desa gas log heater when the heater lites and goes out the pilot lite goes out also
I would start with cleaning the Pilot ODS Assembly and also reseating the thermocouple.
Here is a link to cleaning instructions.
http://www.allpartsinc.com/mmAllParts/Others/Reseating%20Instructions.pdf
Oct 08, 2012 | Desa International Unvented Gas Space...
I have a Desa EFP33PR ventless fireplace. In Auto it works just fine. In Manaul the pilot will light but when I release the gas valve control knob it goes out. Some times, if I rotate the control knob...
It sound like you may need to clean the pilot on the fireplace and then reseat the thermocouple.
Here is a link you may want to look at:
Sep 13, 2011 | Desa International Unvented Gas Space...
The pilot light will not stay onit is desa propan fire place
HI clean the pilot light might be too small check or replace the thermocouple
Jan 17, 2010 | Desa International Unvented Gas Space...
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Jan 03, 2010 | Desa International Unvented Gas Space...
I have a Martin ventless gas log fireplace heater and can't get the pilot light to light. In the past, I've had problems keeping it lit, so I've kept pilot lit all year. The other day I successfully used...
You should the value there should be a pilot ajustment screw
some times it is hidden under another screw but should be close to where the pilot light line hooks to the gas value
Dec 12, 2009 | Desa International Unvented Gas Space...
I have a mod gwp10 glow warm heater and the pilot light will light but when i turn it to the high pos the pilot light goes out every time unless you blow on the thermocoupler. " at least thats what seems...
You have dust in the pilot safety. The system detects low oxygen in the area and weakens the flame on the pilot. Dust imitates the low oxygen. Blow out the ODS or flush it with a tiny drop of rustbuster.
ODS Demo
Nov 28, 2009 | Desa International GWP20T GLOWARM Wall...
My vent free Desa natural log will run for a short
it is likely you have dirty O2sensor, it is incorporated into pilot assembly.turn unit off,use compressed air in a can and blow into spot where pilot flames comes from.this will fix it in most cases.in a small % of time entire pilot assembly needs to be taken apart and cleaned
Jun 25, 2009 | Desa International Unvented Gas Space...
Little spark to start my unvented 8 year old Rinnai. Use match.
Yes - most likely thermocouple, or if the pilot has an orange tip, it will not heat the thermocouple enough to keep the valve energised. Try a blast with canned air or contact cleaner down the tube, not 100psi air compressor.
If that doesn't help, time to ring a gasfitter.
Dec 11, 2008 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
