Question about Gateway FPD2275W LCD Monitor
I got a fpd 2275 gateway 22" lcd monitor there is no power button on it
I have one and fixed it, and using it as we speak.... it's your capacitors.... i replaced 2 and it works great!!.. hardest part is breaking open case ,,,,
Posted on Feb 15, 2009
    Problem Solver:
  • 7 Answers
To make sure that the monitors power is correctly connected, check the power button on the front of the monitor it should be glowing purple. If the purple button is not visible check the power connection.
Posted on Jan 29, 2009
How can i reset my gateway fpd 1930 lcd
At the bottom of the monitor, there are some buttons. Pushing the right-most button (Auto/Set) will enable the automatic configuration to happen. This will "automatically optimize the monitor's image position, clock, and phase."
Gateway FPD1530 User Manual Page 11 Adjusting Monitor Settings External...
Jul 13, 2014 | Gateway FPD-1930 19" Flat Panel LCD...
Complete power failure on gateway fpd 1830 monitor on last bootup. no light on power button and nothing on screen . A fuse maybe ?????
Could be the fuse. But typically it is the caps on the output have failed.
Usually can find repair kits on e-bay and repair if you are experienced.
Nov 04, 2013 | Gateway FPD 1830 18.1" Flat Panel LCD...
How to open gateway FPD 1765 LCD CASE OR BACK COVER
At Last! Okay this is how you open a Gateway FPD 1765 monitor. This Monitor open from the front first to reveal 4 screw under the black trim. Lay the screen face up, NOT FACE Down. So that the GATEWAY LOGO is looking at you. Carefully, lift up the black plastic trim slide a knife or slim tool, or your fingers will do,lifting the trim up a off. BE CAREFUL NOT TO BREAK THE POWER BUTTON WIRES, near the power on button. Then remove the 4 screw holding the back cover on. When you remove these screw the monitor is free, but careful there are 2 set of thin short wires that need to be un plug. You should be able to go for there.
Jan 30, 2011 | Gateway FPD1765 17" Flat Panel LCD Monitor
Gateway fpd 2485 W looked like 60 cycle lines across
Power supply will be the first thing to check, see example of failed Gateway due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 18, 2010 | Gateway FPD1975W 19" LCD Monitor
Message from display FPD 1730 won't go away
press the menu button on screen panel and press exit.
Dec 02, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
When I turn on my monitor I can see the Gateway letters come on the screen but then it just goes dark again. It comes on for a split second and then goes dark again.
joel_herrera, Yes, this is a very common symptom of a failing Switch-Mode-Power-Supply and/or Inverter circuit! Very common in 2-4 year old lcd/fpd's. How old is your's? Do you have warranty? Have you tried the Flashlight test? DO THIS! Reconnect lcd monitor to your fully booted PC with a known good WIN desktop screen. Then power "on" the HD2201 and tell me what happens and what you see or don't see after the screen goes BLACK! Shine a bright flashlight onto the screen at different angles and let me know the results. I'm louie12fix on fixya or lmistyrel @aol.com BYE
Apr 07, 2009 | Gateway HD2201 22" LCD Monitor
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Monitor goes blank
I was thinking about your problem, I just had a similar issue and the problem is that the inverter or the power supply with an embedded inverter had gone bad.
The reason it goes black is because the inverter fails to provide power to the LCD Display.
The only way to fix this is to open up the FPD:
*note these are instructions for the most popular FPD 1730*
1.there should be four screws on the back --> plus two large screws that hold the FPD stand and the Monitor together.
2.Open the back by pulling the cover off
Remove 7 screws holding the frame and the power button for the LCD
3.Remove two screws through holding a silver cover and remove cables.(pinkwhite) (blackwhite)
Please note where they belong before removal**
4.On the edges left and right are two screws 4 total ---> remove and remove LCD off of frame**becareful because the backlight Damaging can cause severe damage to your LCD panel.
5.Choose your model
Your FPD has 3 boards (power, inverter(backlights) Logic Video)
replace the inverter with well known good one
Your FPD has 2 boards(Power with inverter on edges, Logic Video)
replace the power board with a well known good one
6.Then do steps 1-5 in reverse order(putting your FPD back together.
I hope this is significant help
Sep 11, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor will not power up
try makin sure all connections are secure
Apr 30, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway FPD2275W LCD Monitor Logo
107 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
