Question about Sony KP-46WT510 46" Rear Projection HDTV
Location of the convergence circuit board on KP46WT510
Does anyone know the whereabouts of the convergence circuit board on my Sony KP45WT510?
  • Sony Master
  • 8,617 Answers
They are located on the board on the left when looking in the rear of the set ( Brown Board) you can get the convergence repair kit at the follwing link which has the ICs , the six pico fuses and four of the feed resistors, plus it comes with instructions, Here's the link.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Posted on Feb 01, 2009
My sony model kp46wt510 pic looks like its in 3d, what is the problem?
Tv have a problems known as a convergence problems,it dead.The tv convergence board require it 2 STK convergence ICS and some or all it resistors are dead,require changing.These parts on the tv convergence board,must have to replaced these parts to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Aug 06, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sony 65 inch screen transposing images and color.
the only site that provides free instructions with their kits is the following link. Your set uses the same convergence kit as the KP46WT510 that they have.
Feb 03, 2009 | Sony KP-57WS500 57" Rear Projection...
My sony 46 kp46wt510 panel tv has red outline on images
its more likely needing the convergence ICs replaced. You can get the convergence repair kit for your model at the following link which contains both IC the six pico fuses and four of the feed resistors, The kit comes with instructions. Heres the link.
Feb 01, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Location of the convergence circuit board inside the KP46WT510
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Jan 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Red's are out of alignment and I can't fix them
Replace the convergence ICs and the pico fuses you can get a convergence repair kit at the following link which is for the KP46WT510 But its the same one for your model. The kit contains the two convergence Ics all six pico fuses and four resistors. Plus free step by step instructions with pictures that show how to do the repair. Heres the link to the kit.
Jan 24, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony kp 51hw40 real projection tv
Below is exploded view of your Sony KP-51HW40 TV rear side which shows board names and location.
You need to check D Board for convergence ICs and these are marked as IC8001 & IC8002 on circuit board.
Nov 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony kp46wt510 with 6 blinks can anyone help
• +5 line is overloaded. (A, B Boards)
• +5 line is shorted. (A, B Boards)
turn off for about about 4 hours
Feb 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP46WT510 Projection TV
pic of ic known as SDK's
41ae87f.jpg Heat sink is a hunk of metal attached to above
on a sony the convergence board is known as "d" board labeled with a big D
see
LINK
Jan 20, 2008 | Televison & Video
Convergence problem with my KP46wt510...!
They go on the largest heatsinks in your set---the " back" side,
if you look over & down......that PC board must come out to
replace IC's.......
Nov 05, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
KP46wt510
What you need is the complete D board for your TV set. One is available at ptscorp.com, or call them at 1-800-844-7871. Good Luck
Jun 25, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
273 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
