Question about Toshiba E-Studio 3511 Color Copier
Wrong count hi,, and yes they already overcharged me for 60,000.00 copy, and they wont fix the problem, so i have to take care of it on my own,, i talk to toshiba and they told me i need the service maintenance code and that will fix the problem.. toshiba e-studio 281C
  • Toshiba Master
  • 2,794 Answers
You find that answer out on copytechnet.com. There are authorized Toshiba reps available on there to answer your question.
I don't work on Toshiba unfortunately. If I did I would give you the answer.
Posted on Jan 29, 2009
Black copies are coming out faded. How do I fix this? I have already changed the toner and the waste toner bucket.
Does this happen when you print? Not Copy. Does the internal prints come out OK configuration page, meter count, etc.? Did you change the drum unit? Or is the drum unit and toner cartridge one in the same, drum would be blue or green, puts the image on the paper so be careful to not touch it. waste bucket really not a player in this situation.
Nov 18, 2015 | Canon imageRUNNER C5185i Touch Panel...
I have a Ricoh MPC3000, copy count is B/W 770,000, color 87,000, been using it for about 7 years. Is it nearing the end of its usefulness?
Old yes, the newer models have more memory, faster speeds, ect, but if it works... Ricoh "life" is 5 years, or a max copy count.
If its your main color unit, and you count on it, then maybe its time to look. -Carl
Feb 24, 2015 | Ricoh Office Equipment & Supplies
1996 gmc two prong plug in tank melted is there danger
Hi
yes this is dangerous, any heated wires so close to the fuel can be deadly. if they are melting then either the wrong fuse size has been used and this is overcharging the thinkness of the wires, thin wires require low amp fusees where as thicker wire higher fuses. the other issue is there is a possibility of overcharging or two wires contacting each other, this coaul destroy all the electric on the car and would be very costly to repair, I would be looking at wires contacting either each other or the car body "red" positives touching the metal work.
Get back to me with more info
Regards
Dan
Dec 31, 2010 | 1986 GMC K1500
MY CELLPHONE WONT TURN ON
check ur battery and see if its charged. It might be overcharged and it could be alot of stuff, but ur best bet is to go to ur provider store and ask them to fix it or at least tell you whats wrong.
Mar 12, 2010 | LG VX5200 Cellular Phone
I have a reddy heater 60,000,00 btu kerosone
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Sep 19, 2009 | Reddy Heater 60,000 BTU Kerosene...
Wrong count
FYI, if copy 1 side of A4, then is count as 1. If both sides, count as 2.
If copy 1 side of A3, then is count as 2. If both sides, count as 4.
That's the default settings on the MFP.
If u want to be copy 1 side of A3 and count as 1, u need to adjust the setting mode.
Press 08 and ON MFP, Enter 346, change "1" to "0".
Jan 28, 2009 | Toshiba Estudio 200L Copier
My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Dec 03, 2008 | HP LaserJet 1320 Printer
I have a 1999 chevy malibu and it is over charging. I tryed a new alternator and that did not fix the problem. I tryed a new battery and that did not work either. so what do i try next
What do you mean overcharging? Put a volt meter on battery...It should be about 14.5 volts. Since you already replaced the regulator (inside the alternator) The only thing left is that the new regulator is bad. Easy to replace...place paperclip through hole in back to hold brushes until fully assembled then remove.
Aug 21, 2008 | 2001 Chevrolet Malibu
Toshiba estudio 35
What is the copy count on the machine?
Toshiba copiers have service intervals to replace the drum, cleanerblade, corona wires and developer material.
That could resolve your printing problem.
May 09, 2008 | Toshiba e-Studio 350 Copier
Ricoh aficio 450
hi im jules_09,the average copy life as we call it is 60,000 copies after that you will replace the drum,cleaning blade and the developer.see first if the copy meter is already above 60,000 copies then about the print i think it time for you to replace all that is mentioned
Oct 11, 2007 | Ricoh Aficio 450 Copier
Toshiba E-Studio 3511 Color Copier Logo
161 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
