Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Drum wont turn
A bra wire had got stuck was sticking through hole in drum pulled it out and all complete but now drum wont turn turns freely by hand and fills up and emptys makes all the right noises but isn't turning many thanx
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Sounds to me like the belt may have fallen off the back of the drum.
look under the lid and see. if a wd, should be simple enoughto put it back on by removing the back cover to refit.
turn the power off though.
Posted on Feb 04, 2009
My bra under wire stuck in my bosh dryer now when it spins it makes a noise
unless you can pry it out of one of the holes you'll have to take it apart, first try rotating the drum the wrong way to see if it pops out of the hole it went in, failing that, remove the rubber seal retaining ring and peel back the rubber, use a stick between the drum and casing to go fishing... if that doesn't work it's a complete strip-down and the bearings normally protest at that, if you go that far i'd suggest new bearings to replace.
once that's done, maybe consider burning your bra's to prevent further mishaps. or modify an old pillow case with some buttons to wash your smalls in. ;-)
Jan 01, 2018 | Washing Machines
Clicking noise
More than likely a bra wire stuck,,,get a torch,stick ur head inside drum & have a look,,,pulled hundreds out over the years
Jun 16, 2013 | Maytag Washing Machines
During the wash cycle the wire (approximately 5 inches long) from my bra got stuck in the machine. I think it went into the holes in the washing drum. Now I can hear it scraping when the drum agitates and...
I looked at the washer drum online and the holes seem pretty small there are (from the outside looking in some groves that it may have gone thru.}
Have you taken a flash light and with someone else rotating it {drum) by hand gotten a general idea of where it may be sticking thru by sound? then looking closely at that area for a protruding bit of wire? then grabbing i with a needle nose pliers or a wire cutter and pulling it out? I'm not sure how technical you are cuz taking it apart to get to the drum may be a challenge.
Hope this helps you.
Jan 17, 2018 | EuroTech EWF150 Front Load Washer
Electric Dryer Model DCSR473EVOWW has loud scraping sound when drum turning .... sounds like metal on metal
There is likely to be something stuck between the inner drum and the outer casing. In my experience this is most commonly the wire from an underwired bra! (belonging to my wife!)
If the inner drum has holes in it feel the surface carefully all over to try to detect a wire or other object protruding into the drum. If you find something it can often be pulled free with a pair of pliers or pincers.
Jan 04, 2011 | GE Dryers
Metal (wire?) stuck in rotating drum cavity.
Firstly, you can carefully run your hand around the inside of the drum. If you're really lucky the object may poke thru one of the holes enough for you to grab with a pair of pliers. Try turning the drum back and forth to catch the object in the holes. If this doesn't work you can take the sump hose off on the bottom of the outer tub. If all else fails you may have to remove the heater element and more than likely that's where the object is stuck. (Please ensure if you do not but a new element in use some petroleum jelly or washing liquid to get the old element back in, or you may solve one problem but create a leak). Also, when refitting element be sure that it is sat under it's internal bracket or the drum will scrape on it when it turns.
Hope this helps
ps I'm betting evens that it's a bra underwire!
Jul 07, 2010 | Bosch Washing Machines
Washer is putting holes in clothes
Check the inside of the drum when the machine is empty by feeling the entire surface with your hand. Take care as you are looking for something that's got stuck in one of the holes in the drum and is protruding into the drum, and this can often be a wire from an underwired bra!
If you find anything it should be removed by pulling it out carefull with a pair of pliers.
Mar 21, 2010 | Frigidaire ATF6000ES Front Load Washer
When the washer is filling a loud noise is coming from the motor, it sounds like a bearing is going out. It seems to do it mainly when the washer is draining, but it starting to make the noise through the...
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings. Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.) Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub. Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water. Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers. Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Thanks for contacting fixya.com
Nov 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
I have a hotpoint aquarius 1100 washer dryer wd51 was making a grinding noise we turned it off and a under wire from a bra was sticking through a hole in the drum pulled it out and it is complete but now...
The bra wire bears no relation to your present problem.
Remove top cover, screws at rear, and push top cover back.
See if the belt is still on, if it is, then select final spin and see if the motor and drum go round, if it does not, then the brushes in the motor probably need replacing.
Unplug washer, and disconnect the motor. you will find the brushes at the motor plug end, depress plastic lugs, and slide brushes out, if they are less than 5mm long, then replace them
If it is the belt that has come off, you will have to remove the rear panel to refit it.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Hotpoint Aquarius WD63 Front Load...
Bosch Maxx WFL2061 Scraping sound when rotating the drum
under wire of a bra caught in drum , I have taken out hundreds,Close Ireland
Nov 12, 2008 | Washing Machines
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
180 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
