Question about LG DLE5977 Electric Dryer
Dryer model #DEG0332W will not start, no response
I would like to check the fuses, but am unable to locate them.
Please help!
  • LG Master
  • 1,527 Answers
Hello there is a glass fuse on the circuit board .the board might be at the bottom of the machine at the side i'm not sure on this machine also theres fuses that are solder in to the board called wickman you need to test these as well i hope this helps
shaun
Posted on Jan 30, 2009
Kenmore 110.64622300 not starting
Unplug dryer and check the vent pipe to outside clear it and make sure vent is clear ro outside atmosphere.
take back off of dryer and check fuse. Fuse is located on blower housing next to control thermostat.
3399849-j2rqmywrjn05nkl43ld3f3b0-5-0.jpg If the fuse IS open (blown) then remove the filter housing and clean it as well. I have a home made video I did about heat problem but on my video I show how to check all that stuff: below that is my blog page smack dab full of all manor of stuff pertaining to your dryer. Please let me know if this heps. -PawPaw Dan Webster https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes
Jun 23, 2017 | Kenmore Dryers
Motor cannot start on dryer electrolux?
Good Morning Andri - I understand the motor will not start on your dryer, however is there power to the unit? Is the house fuse blown or has the circuit breaker tripped? May I please have the model and serial number? You can typically locate the serial tag on the right or left edge on the side of the door. With this information I can better address the issue. Thank you and I look forward to your response.
Jul 08, 2013 | Electrolux Dryers
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
My kenmore dryer would not heat I change the fuse on the heating element and it start to heat up now it would not start
You have a bad thermal fuse ( a small 1/4" wide by 1" long white piece , with 2 wires going to it , or a 2" long white oval piece with 2 wires , going to it also ) . Unable to tell which you have , and location , without complete model number . After replacing , check your vent hose for kink , and make sure the vent has good air flow to the outside .
Oct 21, 2009 | Kenmore 63942 Dryer
We have hooked up the dryer and not getting hot is there a pilot light on it
Hi, Is this a gas dryer? There are no pilot lights. Remove the small plastic cap in the lower front corner and start the dryer. If the ignitor glows but goes out before the flame lights, you will need to change the coils on top of the gas valve. If the ignitor does not glow, you will need to test the fuse. Here is how to test the fuse on the more popular dryer:
UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
If this is not your model, please get me a model # and I can look your up.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Jul 11, 2009 | Kenmore 63942 Dryer
Dryer quit working. Completely dead
Hi, If this is a whirlpool model dryer, try this: Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. If this is another brand dryer, please let me know the model # so I can assist yyou further.
Thanks
Vic
May 30, 2009 | Dryers
Dryer not heating, help
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
May 30, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Push Button to start and nothing happens.
Hi, The first thing you want to check is that the dryer has power to it. Then check the non resetable fuse. On most models the fuse is located in back of the dryer behind the rear panel.
Once you remove the rear panel, you will see the fuse located on the blower housing (White in color). Take continuity on the fuse. If the fuse has continuity, it is ok. If you an not access the fuse from the back, remove the front lower panel and the fuse is again located on the blower housing.
Other possibilities are door switch, timier, & motor. The fuse is most common problem!!
If I can help further, please let me know.
Thanks
Vic
May 12, 2009 | Kenmore 63942 Dryer
Crosley heavy duty giant capacity plus auto dry control wont dry
Get putty knife and start by popping the top then take the front off and check the heater mounted on the rear bulkhead.
Jan 05, 2009 | Crosley CDE6000 Electric Dryer
Dryer will not start
Your dryer may have stopped itself if the motor overheated. Try it again, if still dead, recheck your fuses, (should be 2-30amp), replace both. Door switch may have failed or door is not making contact with switch.
For more help, locate your model no. and follow this link, it may provide you with some adiitional info. that I am unable to provide without the model no.
http://www.repairclinic.com/0088_8_1.asp#Level1_1
Thank you,
Dave E. (Illeagle)
Jun 07, 2008 | Kenmore 63032 Electric Dryer
LG DLE5977 Electric Dryer Logo
73 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
