Question about Canon LV-5210 Multimedia Projector
Need to replace lamp in canon projector lv5210 need to know how t
How can i get the lamp out
  • 2,097 Answers
Manual is available for viewing/download here. Instructions for changing the lamp are on page 43, and for resetting the lamp counter on page 44.
Posted on Jan 29, 2009
2 Suggested Answers
Noggin
  • 944 Answers
SOURCE: canon lv5210 projector
This link allows you to download the manual. if you need it; http://www.usa.canon.com/app/pdf/projector/lv7215_7210_5210_manual.pdf page 41 especially worth a look page 43 gives all details for lamp replacement if you still think is the problem. Almost certainly the problem is to do with overheating - which is either a bulb problem or a malfunctioning fan. See if the fan runs when you turn it on and check it is clear. Hope this helps :)
Posted on Mar 15, 2007
Canon lv-x4e lamp reset procedure
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Apr 22, 2014 | Canon LV-X4E Compatible Projector Lamp
Canon lv- x5
Have a nice day!
Lampdeng Limited
Jerry
Jan 15, 2014 | Canon LV-LP12 Projector Lamp for LV-S1,...
Canon LV-S1 projector keeps shutting down after a minute or less
Jul 15, 2012 | Canon LV-LP12 Projector Lamp for LV-S1,...
I have a Canon LV-7350 that comes on for 15 secs then turns off.. everything is hooked up correctly. and I have swiched out the bulb to rule that out.. anyone ever seen this?
Hello :
It must be overheating problem . Check the fans . If the fans run properly , then you need to check the fuse or the power PCB [printed circuit board ] . If everything is okay with all of those , then I recommend you to replace the bulb .
Here I'll tell you how to replace it :
  1. Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
    It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
  2. In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
  3. Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
    Please note that in some projectors a small inside filter should also be replaced.
  4. Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
    Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
  5. Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
Warning:
  • avoid touching the bare projector lamp
please rate !.
Apr 12, 2010 | Canon LV 7350 Multimedia Projector
Projector won't power on. Plug it is and all I get
the lamp is past 2000 hours and needs replacing and the timer needs resetting.
Aug 17, 2009 | Canon LV-S2 Multimedia Projector
Sony VPL-ES3
What documents you need for VPL-ES3, let me know please.
Have you replaced Lamp? give details of projector problem to find out solutons.
Sep 12, 2008 | Sony LMP-H150 Projector Lamp Projector...
Cannot reset projector after new lamp installed
hi
Have you reset the lamp timer after replacing the lamp, if not then do so and see the user manual for that.
Viren
Jan 24, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Canon lv5210 projector
Mar 15, 2007 | Canon LV-5220 Multimedia Projector
Projector does not turn ON
try removing the lamp, usually quite easy, you need to find the door for the lamp. lamps are customer replaceable, usually. If the lamp is bad you can usually see it damaged in the lamp. kind of like you might be able to see the broken filament in your normale house hold light bulb. good luck.
Dec 24, 2006 | Canon LV 7345 Multimedia Projector
Canon LV-5210 Multimedia Projector Logo
325 people viewed this question
old marine
old marine
