Question about Kitchen Ranges
Where is the pilot on an old Tappan oven? The top burners work and light, but the oven isnt turning on. There is something under there that is glowing .
  • 5,911 Answers
That thing that is glowing is your oven igniter. Most modern ovens do not have a pilot light. The way the burner assemblies for the oven and broiler work is by an electric igniter with a gas safety valve. When the igniter reaches a certain current potential, it opens the gas safety valve, gas flows and you have ignition. This is a designed safety feature that prevents free flowing gas from entering the oven without ignition. If you can see the igniter glowing and the oven still does not light, more than likely you have a weak igniter. They do wear out with age and require replacement from time to time. There is a separate igniter for bake and broil. Usually, the oven igniter wears out faster than the broiler because of the frequency of use. the following link explains a little theory about igniter types and how they work. It also explains how to replace a defective one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
This is a very simple repair that anyone can do. just make sure you follow al the steps in the link provided. If you have questions, or require additional assistance, please let me know before you rate the solution. If you need assistance in locating a replacement igniter, let me know also. I hope this helps you.
Posted on Jan 29, 2009
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
Where is the pilot light for the oven?
Look inside the oven where the burners come into the oven. Right at that point you should find the pilot light. Here is where you light the pilot.If you smell a lot of gas when you open the door, turn off the gas altogether and let it dissipate. Then turn ot on and then you can light it.
Jan 30, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Jul 20, 2007 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
285 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
