Question about Agri-Fab Agri - Fab Snow Blower - 42"
Snow througher diagnostics
My snow througher is not throughing the snow what could be the problem
I JUST PURCHASED A SINGLE STAGE SNOW THROWER FROM LOWES. WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE VS A DUAL OR MULTI STAGE SNOW THROWER THANKS DON DMH8@AOL.COM
a single is just that a single auger that scoops snow and shoots it out chute their a smaller unit --a dual front auger scoops snow into another auger which shoots the snow through the chute the duals are bigger and they move more and heavier snow
Nov 26, 2016 | Garden
Where can I get parts for it.
I recommend eBay.
Jan 12, 2016 | Garden
Huskee snow thrower spout clogs
Before use spray chute/housing with Pam or WD-40
Also push unit faster to move snow through easier.
Feb 24, 2015 | Huskee 21 in. Single-Stage Snow Thrower
Snow blower will not throw snow far
I take it that you have a 2-stage snow blower, that is is has the auger blades and then the 2-stage impeller. The impeller blade is damaged <<OR>> the motor is to small to through the snow far. If you have a 5-horse engine and throwing heavy snow, the snow may not go as far as the light fluffy stuff.
A single stage snow thrower is not designed to throw snow far, just move it over a bit.
Oct 10, 2014 | Garden
Lost owners man.What oil should I use when changing oil?TORO826le snow througher
For temperatures above 32°F (0°C), use SAE 30W.
• For temperatures between 0°F and 32°F (-18°C to
0°C), use SAE 5W30 or SAE 10W.
• For air temperatures below 0°F (-18°C), use
SAE 0W30.
and you can get the manual here ... http://pdfservicemanual.com/home-appliance/2009-toro-power-max-826le-38622-snow-blower-thrower-owners-manual.pdf
Mar 05, 2011 | Garden
Hello I have a 30" snowplower
Check the drive belts coming off of the engine for condition. Also, check the clutch operation for the auger/impeller--it may require adjustment to tighten the belt sufficiently. You may have to drop the front section off of the drive frame to get at the belts. If you live out in the 'boonies', you might invest in spare belts for the machine as they take quite a beating in heavy snow. Hope this helps!
Jan 22, 2011 | Garden
What all-season tire would you reccommend for a 2002 Ford F150 2 wheel drive truck? Must go through deep Pa winter snow storms
Don't waste your money on all season tires if you are going to be wading through deep snow. Get a good aggresive mud and snow tread for winter driving. I've had good luck with Goodyear's in Eastern Canadian winters. Hope this helps.
Aug 30, 2010 | 2002 Ford F150 Regular Cab
F150 SUPERCREW 4X4 5.4L Got stuck in the snow and
sounds like transmission damaged. if forward gears are operational, suspect transmission failure. If nothing working ( either in 2 or 4 wheel drive) suspect transmission or transfer case.
Dec 25, 2009 | 2004 Ford F150
Chain saw does not get oiled?
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 05, 2009 | Garden
The picture went from clear to snow, but the sound remained clea
Flyback is going out in this unit and would cost $120 for a new flyback if I were to repair it for you. So you have two choices have it repaired on recycle it! The repair these days on TUBE tv's are not very cheap because of having to find parts for them. Rulds2008
May 14, 2009 | Sony KV-36XBR400 36" TV
Agri-Fab Agri - Fab Snow Blower - 42" Logo
29 people viewed this question
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
