Question about Microsoft Xbox 360 Console
Xbox 360 - "Please wait. Reading Storage Device"
After initial start-up and after the reading of the game disc the system freezes and displays "Please wait. Reading storage device". I have never used a storage card/device to save a game or to transfer a game from another unit. I have tried re-starting, unpluging, and crying...but nothing seems to work. Any ideas out there?
Thanks!
  • darincwik Jan 29, 2009
    drethegiant,
    Thanks for the quick response! I did just what you suggested. I removed the hard drive and simply replaced it...and it worked! Thank you very much for your assistance...now my 7 year old son can put a hurt on me in Madden '08. Maybe I should have kept the Xbox broken!
    Thanks Again!
    Darin
  • Andre Runkle May 11, 2010
    does your xbox have a hard drive? Because you need a hard drive or a memory card to save a game with an xbox.. if you do have a hard drive you should take it off and put it back on; also how long has this been happening?
  • 85 Answers
SOURCE: storage device not found
Saving a game requires you to have a Hard drive or memory card did you purchase the premium edition xbox 360? you can look on the outside of the xbox 360 box it will give the specs and what came with the system. If the hard drive is not on the list then you will need to buy one the xbox doesn't come with any internal memory like the systems in the past have. you will need to purchase a HD or a memory card. If you have the premium edition let me know ill instruct on how to set it up.
Posted on Dec 27, 2007
danielrp34
  • 14 Answers
The hard disc drive on the top is probably knocked out of place. It says HDD on it.#1 hold in the small button on the top.#2 Pull off the HDD.#3 Under neath the HDD There are instructions for getting it back on
Posted on Jul 10, 2008
SOURCE: Xbox 360 Not Reading 512MB Microsoft Memory Card
make sure it is fully plugged in and go into settings and then memory and make sure it pops up and then select it if not maybe halo needs a hard drive but i dont think but if it doesnt pop up in memory then its probably a faulty memory stick
please rate well
Posted on Jan 06, 2009
lostinfamily
  • 149 Answers
SOURCE: Xbox 360 deleting profiles and has no storage device
This sound like your hard drive took a ****. But before we count out the Hard drive your BIOS battery may have just died. If your warrenty is still vallid then maybe XBOX can help but if it is out then try replaceing the BIOS battery first. This would be the cheapest way. If you are uncertain what the bios battery looks like it is a flat battery that is about the size of a quarter. After you have replaced the battery and there is still no change then the next thing I would recomend is replaceing you hard drive.
Posted on Feb 26, 2009
damonumber5
  • 340 Answers
SOURCE: Xbox 360 transfer kit disc not reading - says 'mixed media'
Have you used the usb port on the back of your console, not the one on the front? if this is not the case, the best place to go is www.xbox.com/support or ring on 0800 587 1102 for more info.
If this helps remember to vote, to help others with the same problem.
Posted on Jan 23, 2010
I won't read the games but reads dvd's after installing a new hard drive. How do I get it to read games?
Try formatting the new hard drive.
To format a storage device
  1. Start your Xbox 360 console without a disc in the tray.
  2. Go to the Settings hub, and choose System.
  3. Select Storage.
  4. Highlight the storage device that you want to format, and then press the Y button on your controller.
Oct 18, 2015 | Microsoft Xbox 360 Console
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
Had a Power Surge and now my PS3 will not send a signal to the TV. Yes, PS3 was plugged into a surge protector, but it failed. I can turn on the PS3, put disc in and eject them with no problem. The...
If its been reset it will originally not display video out HDMI, first try component cables. Then try this...
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to Sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your back-up you made prior to doing factory/hard reset (optional, if you created a back-up).
Hopefully this will solve your freezing problems.
Problems/symptons that this appears to have resolved:
- Freezing when doing anything
- No harddrive activity
- Freezing when trying to use onboard keyboard or bringing up keyboard
- Game/movie disc freezes system
Jun 02, 2011 | Video Game Consoles & Games
Hi my xbox 360 keeps telling me to open tray after a disc is inserted. it says reading then it says open tray.
1: Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Hold the disc by the edges without touching the top or bottom surfaces. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. 2: Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: Make sure the media type and the disc region code are compatible with the console. 3: If your Xbox 360 console can't play multiple game discs, try clearing your system cache. Here's how: On the console, go to My Xbox, and then select System Settings. Select Memory. Highlight any storage device, and then press Y on your controller.Select Clear System Cache. If you still can't play a game disc, try the next solution. 4: If the solutions above did not resolve your problem, please send Microsoft your Xbox 360 console for repair..
Mar 01, 2011 | Microsoft Xbox 360 Console
XBOX 360 cd rom is not reading discs
1. Make sure you REMOVE any discs from your XBOX' tray. 3. Turn on the console again, either by using the controller or the POWER button (NOT the EJECT button) and WAIT for the initial XBOX setup. ... This fixes the OPEN TRAY error 100 % of the time on my XBOX 360. XBOX 360 cd rom is not reading discs Google Search
Jan 13, 2018 | Microsoft Xbox 360 Console
Disc read error clean disc
The laser hasn't necessarily failed. This has happened to me in the past with certain games. I solved this problem by deleting the Xbox 360 cache. This can also solve various other problems on the console.
Clearing the cache removes all game updates which means you have to download them again but it WILL NOT remove your save games and your content so it's safe.
To clear the cache, do the following:
1. Go to the System Tab and select Storage Devices.
2. Highlight your HDD and press Y for options.
3. Enter the following button sequence: X, X, LB, RB, X, X.
4. When the system asks if you want to perform maintenance, choose yes.
5. Now restart your console.
If this doesn't work I'm not sure what to suggest, it probably is a hardware fault.
Hope this helps a little.
Nov 15, 2009 | Microsoft Xbox 360 Console
Ps3 40gb wont read disc
Contact Sony @ 1-877-253-SONY to request an RMA for your machine, this is a common issue and you should get a new machine.
Sep 02, 2008 | Sony Playstation 3 (PS3) Console
Not reading any disc
I was playing devil may cry 4 for half an hour and than it freeze.I turn off the console and back on again from this moment it won't read any disc or any games i try.Please tell me what to do.Thank you.
Jun 10, 2008 | Sony Playstation 3 (PS3) Console
PS3 having trouble reading game discs!!!
hey guys. the problem is that the blue ray reader is some how broken and it won't work. mine kept freezing during games like after 3 mins. and it wouldnt read any more discs for that day. you need to change the blue ray reader and that costs about 175$. thats alot of money and its probably not worth it.
Apr 06, 2008 | Sony Playstation 3 (PS3) Console
Games read but will not play
Try Reseting dufault settings through System settings...
Dec 27, 2007 | Sony PlayStation Portable (PSP) Console
Microsoft Xbox 360 Console Logo
334 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
