Question about Mitsubishi VS-50605 50" Rear Projection Television
Snapping or Popping Sound
My VS50705 makes snapping or popping sounds after the TV has been on for 20 minutes or so. After a while the TV will shut off. Is there anything I can do to fix this problem??
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Posted on Sep 20, 2007
  • Lashawn Robinson Sep 21, 2007
    First to find what is wrong you need to do self test.
Popping, snapping sound
Hello fulby2001,
Have the CRTs checked for grid to cathode shorts. The CRTs do this (pop and crack) when they have Grid Cathode shorts. I would advise having a qualified TV technician do this for you.
Thank you,
I hop this helps
Shuttle83
Sep 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Tv cuts itself off after about 2-3 minutes
try unplugging it to reset it 7 call the manufacturer. is it under warranty, do you have a dct?
Apr 21, 2008 | Televison & Video
Problem with sylvania 6413TC 13"tv
This is a runaway high- voltage condition. When the TV turns on, the high voltage goes out of sight, causing the snapping or popping sound. Then the high voltage shutdown circuit takes hold, and the set cycles on and off repeatedly.
Dec 20, 2007 | Sylvania 6413TC 13" TV
Audio issue with Sony Bravia tv
Each time our TV starts the snapping sound we reboot the cable box. Problem solved.
Oct 09, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Static or popping sound
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jul 24, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Popping noise
Does the " popping" noise come through the speakers or from the TV chassis ? If it is coming through the speakers you could have a bad solder joint somewhere in the tuning circuit. If it is a snapping sound coming from the chassis, then you probably have something arcing in the high voltage circiut. If this is the case then you should have it checked out since this can cause other parts to short shutting down you set completely.
Jan 21, 2007 | Hitachi C25-RF35S 25" TV
Mitsubishi VS-50605 50" Rear Projection Television Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
