Question about Corona 23-DK Compact Heater
Heater produces bad smell and fumes that make our eyes burn
We don't really know how to use this heater. We really need it because we don't have heat. Can you Help Us?
  • Anonymous Feb 15, 2009
    we have used the corona 23-dk for years with no problem, now it is producing terrible fumes and the wick is not igniting as easily as before.
Hi I hope I can help you with your heater. I own 3 of them. Once you light your heater, give it time to completely light around the ring. Once it does, adjust your burner so the flames are evenly around the ring. Make sure you are using 1K kerosene too. That makes a big difference in the use of your heater. If I can help you any other way please feel free to contact me.
Posted on Mar 02, 2009
    Problem Solver:
  • 10 Answers
Good solution from mommayoshi, but also, you need to change your wick once per heating season - more often if you have a cheap wick.
On the fumes, I used mine to heat our finished basement and would light it in the garage (there are bad fumes when you first light it) and then would set it back in the garage to turn it off. (Again, bad fews while it cools down).
Posted on Nov 14, 2009
I have a ready heater pro 100 and it fills the room/garage with a gas that burns the eyes and really stinks??? It is propane???
Could be escaping gas. Gas providers usually ensure the gas they supply smells bad so leaks are difficult to ignore. I have never experienced stinging eyes from the gas though.
Stinging eyes and possibly a dry and scratchy throat sound more like a heater that is burning inefficiently and producing excessive amounts of soot and carbon monoxide and probably other foul and potentially dangerous substances in addition.
All heaters produce such gases and should not be used without ventilation but when a heater is in a good state of repair and burning efficiently the emissions and the ventilation required are minimal.
From your description it would seem something about your heater is faulty and you should not be using it until it has been checked and declared fit to be used, when you should find it no longer stinks or makes your eyes sting.
One thought, if you have a dog about the place that has spent all summer marking his territory on your heater, it will stink, really stink, and make your eyes sting for a considerable time...
Feb 20, 2015 | Heating & Cooling
Smell emitting from gas heater
Carbon monoxide is completely odourless and every sort of combustion of a carbon or hydrocarbon fuel produces carbon monoxide. That is why heaters should not be used without adequate and efficient ventilation and heaters should be kept in good order because efficient combustion produces less and inefficient combustion produces more.
Inefficient combustion and the need for service can often be recognised by the characteristic blue flame being tinged with yellow.
Heaters burning inefficiently often produce a smell for the sensitive or stinging eyes but that is not caused by carbon monoxide.
The gas itself is also odourless and the characteristic smell is added to warn people of leaks. I think the added gas smell tends to settle or separate from the liquid gas to some extent so there will be times when it is so concentrated it isn't entirely neutralised by the burning process, at least that is my theory.
Jun 18, 2017 | Heating & Cooling
Heater putting off smell that burn eyes and nose
could be fumes if it is gas if so needs service and turn it off
Jan 06, 2011 | Heating & Cooling
I just bought a 30K ventless wall mount heater and have a 24X30 insulated garage. I set it on 2 and it keeps it about 60 degress but the smell burns my eyes and stains my clothes. It's brand new. I have it...
You need to ventilate this area while the units running! This is potentially a lethal situation!
You are competing with a flame for oxygen and breathing the carbon monoxide gasses
from the heater! Both unacceptable scenarios! you can easily die in this environment!
I cannot stress this enough! You need to open a window or crack the door enough to allow air to circulte and gasses to vent out and escape, If the burning of eyes is really bad your unit may not have sufficient combustion air, I can t tell you without seeing it precisely, you better vent that room though!
Dec 24, 2010 | Reddy Heater RLP100 Portable Forced Air...
I have a allpro propane space heater. it fumes and burnes my eyes
these units have to be used in open area, with air flowing, they produce carbon monoxide...
Dec 19, 2010 | All-Pro Propane Garage Shop Heaters - All...
Bad odor, burning eyes from fumes.
It sounds as though some Plastic part is being heated up to Fuming Point, being melted, and releasing toxic gas, I would advise not using it until you can get it looked at by a professional.
Feb 20, 2010 | Procom ML300HGA Heater
Burning eyes, can't breathe.
These produce large amounts of carbon monoxide, so you essentially are poisoning yourself. Leave the garage door open part way when using it.
Feb 10, 2008 | Reddy Heater RLP100 Portable Forced Air...
Corona 23-DK Compact Heater Logo
358 people viewed this question
Top Corona Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Corona Heating and Cooling Expert? Answer questions, earn points and help others
