Question about Dell Dimension 2400 PC Desktop
Does the dell dimension 2400 has an output to connect the to tv
I just want to know if it can work through the tv or not and if so how can it be done.
  • 6,784 Answers
I assume you are talking about using your TV as a second monitor?? if so, you will need to have a video card that is able to work this way. if you do, its a done deal. most video cards have optional hook ups in the back but, if its an integrated card, it may not. use the dvi or s-cord for this to work correctly. hope this helps ya:)
Posted on Jan 29, 2009
  • 33 Answers
You will either need a new video card with a compisite (yellow connector) or a s-video connector (looks like the end of a mouse), or somthing called a scan converter. Either of these products will allow you to use your telivison as a monitor for your computer. The last option is to get a telivision with a monitor connection on it. They are called SVGA connectors. If you go this way, you will need a Male to Male SVGA cable. Good Luck!
Dell Dimension 2400 manual
Unless your TV has a VGA socket (it should be blue, have many pins and look just like the one on your computer monitor,) and an audio-in jack (it'll look something like a 3.5mm headphone jack,) you cannot connect the PC to your TV without other accessories. If it DOES have those ports though, just buy a two-ended headphone cable and an SVGA connector cable (unless you can use the one from your computer monitor,) from Monoprice.com, hook them up, hit 'input' on your remote with both TV and PC on and you're in business! Best of luck with it!
Aug 30, 2012 | Dell Dimension 2400 PC Desktop
What kind is motherbourd
The Dell Dimension 2400 motherboard is proprietary to the Dell Mitac Chassis. It should work in any Dell 2300/2350/2400/4600/4700 case. The main item is the Dell specific power/control panel connection. If you move the board take the control panel with it.
(Personally, it isn't worth the effort)
Jul 05, 2010 | Dell Dimension 2400 PC Desktop
Can't get router to connect to Dell Dimension 2400 desktop
Try turning OFF DHCP from services. This may fix your problem. Look for "DHCP Client", double click on it (or right click and choose properties), STOP the service, then set it's startup type to 'manual'. That'll kill it. See DHCP is what "Gives out/assigns addresses" and on the ONLY PC, it is the First one... 192.168.0.1... Both PC's will be assigning themselves as that, and that will cause a conflict. As the Router now does the DHCP work. Of course ensure you DO have DHCP set on router.
Feb 12, 2010 | Dell Dimension 2400 PC Desktop
I am having difficulty connect my dell dimension 2400 to my toshiba plasma. when booting it shows me the blue microsoft screen,but when it comes to the point of hitting ctrl alt delete to enter my password...
try safe mode on boot up and then change the resolution 60 800 X 600 pixels and work your way up from there until you get the problem again then back up one step (or figure out what is the max resolution of your plasma.
Nov 10, 2009 | Dell Dimension 2400 PC Desktop
How do I get my TV to display my Dell Dimension 2400? I have the cables for the connection and I have connected other computers to to TV with no problems-- it seems this is more of a software/display...
Try this: right click on the desktop (wall paper picture) and select "Properties" (up to XP) or "Graphics Options" (Vista). You should be able to select you TV as a second display. The TV option may only show if it is connected.
Jun 08, 2009 | Dell Dimension 2400 PC Desktop
Desktop screen won't stay on
how old is your screen, if its older than 2-3 years mostly its gone and you need to replace it. If its in warranty then contact dell customer support. Life of screen can be around 3 years after that i may not work.
Another test is to connect it to some other computer and see if its working, then we can focus on some output issue from the CPU.
Apr 15, 2009 | Dell Dimension 2400 PC Desktop
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html?tag=mncol;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=89&name=DVD-Burners&
Cheers!
Mike
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
Video out on dimension 2400
all of those are controlled by the video card-software management panel..go to dell support website, and make certain you have that latest driver set..then you should be able to enable any of those options.
Oct 09, 2008 | Dell Dimension 2400 PC Desktop
Video output on dell diemnsion 2400
Please check all power cords and monitor connections first.Then make sure your video card is seated properly.If it is on-board video(connected straight to back of motherboard)and these solutions don't work,you may be looking at a fried motherboard.
Feb 19, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
293 people viewed this question
Alun Cox
