Question about Apple iPod nano
Screen gone dark
Hi there - screen went dark for no apperent reason - please help!
  • valmangan Feb 05, 2009
    Thanks so much but no joy I'm afraid - looks like a defected screen - it's going back!
  • EakinLC Apr 12, 2009
    New Nano *G was synched with Mac Air Computer. Headed to Eaurope (hopefully w/o Mac Air) Bought Generic Charger. Nano only works when charger connected; otherwise no response. Easter Bunny ate iPod book, but on-line APL nano book read and followed. Thanks and Happy Holidays !!
  • 2,071 Answers
It is natural to ipod the screen will be dark if has no power unless the LCD of your iPod is defected even it has a power its remain dark that’s the symptom of defected LCD screen. I hope your problem is a power failure only. Make sue your iPod is fully charged and then toggle the hold switch on and off. Then reset your iPod nano; Toggle the Hold switch on and off,(Slide it to Hold then it off again). Then press and Hold the Menu and Center (select0 buttons simultaneously until the apple logo appears ,about 6 to 10 seconds .You may need to repeat this step . If you having difficulty resetting your iPod set it on a flat surface .Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel,and not near the center. Then If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try your iPod nano with a different USB port on your computer, not a USB port on your keyboard or hub. iPod will stop charging if the computer, or portable computer, it's connected to enters standby, hibernation, or sleep mode. To charge your iPod, connect it directly to a computer's USB port and make sure standby, hibernation, or sleep mode is turned off. If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly. If you have an Apple iPod USB power adapter you'll be able to charge your iPod without leaving your computer powered on. If all procedure above for power to on is not working then its better to replaced the battery with anew one so its works normal again.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 29, 2009
VIZIO M701D-A3R SCREEN GHOSTED WENT DARK OVER HALF
Aberrations of picture on these sets can usually be traced to a problem with the t con board.
May 26, 2016 | Vizio Televison & Video
Panasonic TV TC-2175C, display turning dark
There are mainly two reasons for this fault. The first one is with its screen voltage settings. If the screen voltage settings have gone down [it can be happen automatically in rare cases], the screen will look dark. The second one is with its video output section itself. Anyway, you have to seek an experienced service technicians' help in this matter, if you are not handy in electronics.
Jul 02, 2012 | Panasonic CT-27G13 TV
Hi, I have a JVC N835 camcorder and for a reason I can't understand the screen has gone black. I can vaguely see the screen info at different angles and it appears the light has just died. I have...
ive got this camcorder too, and my friend has a similar one that her screen went blank, and literally froze. it could be that it has been used too much, or that you have droped it, or the climate has been too hot or cold. take it into a shop that sells this camera (even if you didnt buy it here -- they may help you) and see if they know...
HOPE THIS HELPS!!!
meggie xxoo
PS; did you touch that little hole on the bottom right hand corner on the side with the screen??? ***IT IS RESET !!!***
Nov 22, 2010 | Cameras
I have a 42" Sony Plasma Model# PFM-42B1 was watching tv when picture went out. Red standby light keeps flashing. Was told to unplug for 5 hours then plug back in & count how many times it blinks,...
There are a number reasons why this might happen:
  • The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  • The panel has died - Need a new panel
  • A cable has worked itself loose or is broken
  • The inverter has gone - Need new inverter
  • The driver board is faulty
Thanks
Oct 01, 2009 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Dark screen
Sounds like it is the backlight that has gone. New screens are a lot more reasonable cost option now and they tend to have the backlight incorporated into them. Replacing a backlight is not a simple procedure by any means. If you're not sure about changing components yourself then take it to a repair shop.
Jun 09, 2009 | Packard Bell (030069) Sound Card
The screen went dark on jmv 111
Dark as in gone or dark as in the image is still viewable?  How does the onscreen menu look when the image is dark/gone?  If the onscreen menu looks right and the image is still dark, you might want to check the cables or another input.  If another device using different cables and another input looks fine, you may only have a problem with the input/cable you are using to view the movie.  If the onscreen menu is also dark, then I would think there is an internal problem that needs looking into.
Mar 23, 2009 | Jensen Car Audio & Video
Black/white/rainbow screen
Sounds like power board issues, if your able test the voltages coming out of it and see if they are correct
Nov 23, 2017 | Insignia 19 in. Widescreen Flat-Panel LCD...
Laptop's dark screen is pissing me off
Hi, i have an Acer 5100 and the screen is really dark... can only just make out the screen. I have tried the fn key trick with no luck. I have replaced the inverter and also the screen.... again no joy. Can someone help me please :)
Jul 28, 2008 | Acer Aspire 5100 Notebook
Screen very dark
hi sir you got a burnt fluriecent or a deffect transistor driver to it refer to qualified person to re change , but this is the fault sharply cost i2 20$ please don't forget to do excelent rate cause i here to help you regards
May 06, 2007 | Panasonic DVD-LA95 Portable DVD Player
Dark screen
Im sure you have tryed the brightness on the monitor?? if not do so then if thast dont work go to the back of the monitor and try to adj the screen control and bring up the main screen ever so slightly.
Mar 29, 2006 | AMD eMachines Desktop System w/ 17'' CRT...
Apple iPod nano Logo
172 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
