RCA TV Model no 52RH8LA problem - switches on when it wants to. All other functions fine when operating. When TV refuses to switch on, standby LED flashes red. To date: already replaced all electrolitic caps in power supply and checked secondary power supply caps. Suspect from discussions with other technicians, capacitor on main motherboard.
SOURCE: Main power light turns on but i have no picture or sound
Take a closer look at the power board fuses. There is a fuse numbered 106 a little ways away from the rest of them. I have this same model and got it working long enough to diagnose a bad flyback transformer by replacing this fuse with one from Radio Shack. At some times, I could put in a new fuse and have the set work for a few weeks. The flyback transformer is available from parts.pioneerelectronics.com for around $60.
Posted on Mar 20, 2009
SOURCE: RCA D52W19B light on power
where do ypu get the cp150 at thanks
Posted on May 16, 2009
ripleymojica
  • 643 Answers
SOURCE: sony kf-50we610 power led flashes red 5 times
Needs new lamp or the fan is out.
Posted on Jun 02, 2009
SOURCE: power/standby led beeps red light 6 times
crazyford359
Your Thermal fuse is out. I just replaced mine, the part is only $4.85 on Sonyparts.com. Ordered (2)
Posted on Feb 21, 2010
welcomejee
  • 10594 Answers
SOURCE: tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Posted on Jul 28, 2010
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
My Samsung tv model CS - 29M20MH switch onto standby mode with led flashing several times then switch off - no screen coming on
From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jul 20, 2015 | Samsung Televison & Video
My sony bravia LED flat tv goes on and standby then on and then stanby again..and afterwards stucks on standby at all.Is the system controller has failure or its power supply?
Before go, the standby/power LED will blink to a certain times, and these blinks are called blinking codes, and are fault indications. From the number of these blinks occur at one time switch ON, you can get an idea about the fault circuit stage inside the TV. If you wish to get more details about these blinking codes, check this link. if you're sound in electronics, you may get it repaired by yourself.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 03, 2013 | RCA Televison & Video
Usevally after power off to the tv for about one hour, if i switched on the tv, the standby LED of the tv blinks about 5 to10 minutes and the same time tv will not on & the remote also does not...
It most likely is a error code indicating something is not quite right in the power supply of the set----I would suspect it to be a puffed up filter cap and if so the wait will gradually get longer until the set will never turn back on.
good on left and bad or failing one on right--tops have to be perfectly flat.
Jun 14, 2012 | LG Televison & Video
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
RCA Model M50WH187 DLP TV - lamp cuts out
The lamp ballast supplies power for the lamp, and it is probably going out. You can probably find one on eBay or ShopJimmy for under $100. It looks like a little box and it will be near the lamp.
May 01, 2017 | RCA Scenium M50WH187 50" HDTV
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Feb 18, 2008 | Televison & Video
Power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Sep 26, 2007 | RCA 32F531T 32" TV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
