Question about Amana RanARG7302 Gas Kitchen Range
Amana broiler problem
We have an Amana gas range. Everything works except the broiler. Any suggestions?
  • 5,911 Answers
Each burner manifold in the oven has its own igniter. If the igniter is defective, the burner assembly will not light. The igniter has to be functioning properly in order for the gas safety valve to open. This is a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. This reduces the risk of explosions.
There should be a flame spreader metal plate covering the access over the broiler. You will need to access the broiler so you can view the broiler manifold and igniter. Turn the oven setting to broil and make sure the igniter begins to glow. If the igniter fails to glow, replace it. If the igniter does glow, but you still do not have ignition after 90 seconds, the igniter may be weak and still require replacement. The following link explains oven igniter types, their current potential, and how to replace them:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Posted on Jan 29, 2009
Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Feb 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Oct 03, 2009 | Amana AGDS902 Gas Kitchen Range
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven won't come on
check the ignitor for the oven even it is glowing it may not be pulling enough amps to call for gas this is a very common problem with maytag and amana ranges replace the ignitor and it should work fine
Jul 12, 2009 | Amana RanARG7302 Gas Kitchen Range
Amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
Mar 18, 2009 | Amana ARGS7650SS Gas Kitchen Range
Our Electric Amana Self Clean Oven, the broiler is not working? Help! The oven and stove top work just fine, but when we go to turn on the broiler the broiler doesn't come on, the selection buttons all...
canoyu physically inspect teh element for damage, perhaps its broken. or as wireleadingto the rearof elemnt has buntoff. you can check , but turn offpower first, the wires are always live
Feb 21, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana gas oven will not stay lit
i'm having the same thing happen to me however the broiler works fine.
Nov 17, 2008 | Amana ACF3355 Gas Kitchen Range
Amana Range ARG7300W
yep open the oven door unplug the range remove the racks on the bottom liner should be some screws remove them then take the liner up and out if there is a flame spreadder on the burner tube remove it at the back of the burner bar should be the ignighter most new ones are generic you just cut the wires on the old one and splice the new one on with cerramic wire nuts make sure the wires are away from the burner bar reverse dissambily turn oven on should light within 30 secs if ya pluggedit back in
Dec 29, 2007 | Amana RanARG7302 Gas Kitchen Range
Broiler not workig
The flame maybe not enough try to clean the gas nozzle at back potion of the oven , look for small wire to clean the clug by dust and rust , after cleaning test the flame , the burner will increase in flame .
Dec 24, 2007 | Amana ARGS7650SS Gas Kitchen Range
Amana RanARG7302 Gas Kitchen Range Logo
890 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
