Question about Maytag MZD2766GES Side by Side Refrigerator
Switch sticks for the ice and water. It wont shut off
This unit has a rubber pad that you push your glass against which ativates a little switch. When you pull the glass away the rubber sometimes doesnt pop back and the water or ice keep running. I've already replaced the rubber pad. That helped for a while but its doing it again. Is there any fix to this. I see the newer models no longer use this rubber pad.
    Problem Solver:
  • 16 Answers
Remove the water drain and the two screws behind it and lift up to remove the push button panel,unplug the push button panel. remove three screws holding the dispenser unit in place,sliding the water uotlet out of the way as you do. Next get to back of rubber cover and put a little lubricant(silicone lubricant would work,not too much, then test.Then test and reassemble.
Burkes of Byron Ga and Orlando Fla.
Posted on Feb 04, 2009
Ice Maker works but water dispenser doesn't
The solenoid valve is located where the water line connects to the fridge. There is a micro switch that the paddle in the door operates when you push a glass against it. Sometimes the plastic locating pin that holds the switch in position breaks and allows the switch to move away from the actuating lever.
Aug 26, 2017 | LG Refrigerators
Electrolux EI23CS55GSI - Water Dispenser Will Not Stop Running
sounds like the paddle you push to dispense the ice and water is sticking,if there's a rubber pad there try moving it to see if it frees it up,if not it looks like you have to replace the whole part 242100018 go here to see it
https://www.repairclinic.com/PartDetail/Dispenser/242100018/3513417
Jan 18, 2018 | Electrolux Refrigerators
Our fridge's water/ice dispenser will not shut off unless the child lock is turned on. Without it, the water/ice keeps coming out just like a cup has been placed there. What's going on and what needs to be...
in the back of the fridge u have a water solenoid itll be blue probably it has a wire harness that goes to it pull the wires off of it and see if it has constantly got power to it if u dont then ur solenoid is stuck and needs to be replaced if it does have constant power to it ur push button is stuck in the front where u push fpr the water to come out u have to find the lil switch and see if it is hung up u may can tap on it to break it loose but if it is stuck its gonna have to be replaced hope this helps
Mar 01, 2010 | Refrigerators
When I turn the car off, the rear lights stay on, what could be the problem?
Your brake switch is on, likely due to a rotten contact pad
If you look under the dash by the brake pedal, you will see the brake switch mounted against the pedal with a little plunger sticking out.
The pedal contacts this plunger with a little rubber cushion that gets brittle with age and falls apart.
Once this happens the plunger no longer contacts the pedal and extends at all times, leaving your brake lights on.
Verify the pad is missing. If it is not missing and you can see the pedal depress the plunger completely at rest, then you have a faulty brake switch...... it's always the rubber pad though :)
Here is a picture of roughly what to expect:
Sep 20, 2009 | 1995 Mitsubishi Eclipse
Ice maker not working bosch refridgerator
Had the same problem. If there is ice in the bin make sure the ice bin is in all the way. there is a
drive gear in the back that has to be engaged. If the
bin is emty open the little door where you can see
if there is ice, on the left you will see the square
end of the ice maker unit. Slip your fingers under
the front face, palm of your hand facing up so you
can feel the bottom of the front of the unit. Over
to the left you will feel a button that you can not
see. Just push it in for a few seconds and the unit
should start. One other thing, make sure the limit
switch is pulled down, thats the plastic on the
wire which shuts the unit off if it is full. Good Luck.
Sep 20, 2009 | Bosch Evolution 500 B20CS50SNS
Push the water dispenser, water starts but then stops abruptly
Yes , replace the water inlet valve . The piece the wall water line connects to .
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
TFX22CR GE refrigerator TFX22CRXFWW does Not dispense ice.
I had this problem with a similar refrigerator. The problem was the slide switch burns itself especially if you slide it from ice to water while holding the glass in to get ice and water into your glass. Better to slide it to ice, press the glass in to get ice, release the glass to stop the ice, slide the switch to water, then press the glass in again to get water. I "fixed" mine by removing the control panel and soldering some of the connections on the slide switch together so that we now have no crushed ice function, but the ice cubes work again. You can also replace the circuit board in the control panel to restore it to like-new operation. I could not find a place to order just the slide switch.
Not sure if this is the same problem with your unit, but sounds the same.
Dec 06, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Water or ice will not stop after removing glass.
Although I don't have this problem, I took my dispenser apart tonight for a different reason. Moving the lever with the glass actuates a mechanical switch. It's a really simple mechanism. If I were you, I would check to see if that mechanical switch is sticking. Maybe someone had a glass of soda or something sticky, which splashed up there when they got ice. That could be enough to gum it up.
Taking it apart was not tough. The plastic border pulls right off. Then the assembly that has the buttons and lights on it can be removed by pushing it downward enough so that it clears the plastic holders, and then you just pull the top edge towards you. At that point I unplugged the fridge so I couild disconnect some connectors. Then 4 screws gets the whole glass switch assembly out. You should be able to inspect the mechanical switch operation at that point to see if it is sticking.
Good luck.
May 22, 2008 | GE GSH25JFR Side by Side Refrigerator
Psc23sgrd ss ice/water dispenser not working
It is possible. When you put hit your glass against the paddle to you hear the switch click? And can you still select between water, cubed, and crushed ice? Also does the light by your glass come on when you but your glass against the paddle?
When you put your glass on the paddle it pushes in a microswitch. That microswitch will power the light if it is working and also sends power to the board you are talking about to dispense ice or water depending on what you have selected.
Nov 03, 2007 | GE Profile PSI23NCR Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
138 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
