After recording with my dvd recorder how do i finalize my dvds?
I have spent 2 months looking for this answer myself... and at last success! i downloaded the user manual from funai(they made this model) available here: http://www.funai-corp.com/6pdf/om/MWR10D6.pdf on page 38 it instructs you to press setup on your remote, from the drop down menu you need to select disc edit and then select finalize. this aggravated me at first because nothing happens when i hit the setup button, i powered off the unit and hit setup before the disc loaded. this step is not mentioned but is necesary. you cannot finalize a disc after it has loaded to the title menu.
I have found you can't press the disc edit button while you are in edit mode. First make all your chapter edits etc... Then return to the main menu. At the main menu select play (not edit) your dvd will start to play then press stop. Now you should be able to access the disk edit button. Hope this helps. [email protected]
Thank you
SOURCE: recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
SOURCE: Dont know how to finalize dvd after recording on magnavox vcr/dvd
You can find a copy of the manual on the web link provided here:http://tv.manualsonline.com/manuals/mfg/magnavox/mwr20v6_1.html Print a pdf copy for yourself. If you need more help the customer care for you dvd/vcr player is at this telephone number. 1-800-605-8453 give them the model number of your dvd/vcr unit and they will be able to help you. I hope this information helps you with your problem.
SOURCE: Philips Hard Disk/DVD Recorder Model DVDR3370H/97
There was a compatibility issue with this model. Philips released a software update for this model.
Follow this link:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=DVD_HOME_THEATER_CA&sct=DVD_HARDDISK_RECORDERS_SU&session=20080216151231_81.77.115.133&grp=HOME_ENTERTAINMENT_GR&ctn=DVDR3380/05&mid=Link_Software&hlt=Link_Software
Read and follow the instructions CAREFULLY.
SOURCE: My JVC DR-MV7 will play
My JVC DR-MV7 will not accept any disc for playback. I insert a movie disc and it consistently rejects them. After about 15 to 20 attempts, sometimes it will stay and begin reading the disc. It also sounds like some internal components are encountering some resistance (moving parts inside?). Any ideas?
SOURCE: Magnavox DVD recorder...finalizing problem
The manual isn't too helpful either - "Recording error other than below," it says. There are a couple of possibilities. The Philips/Magnavox/Funai recorders automatically record in VR mode when you use +R discs (there are two possible recording modes - V Mode and VR Mode). Is it possible that you have switched disc types lately? If you are currently using -R discs, switch to +R and vice versa. The manual states that +/-RW discs take a while to initialize.
I couldn't find a full factory reset on that one, so you may have to unplug the unit for about 20 minutes to restore all the defaults.
Another possibility: Finalization requires some extra space on the disc. If you accidentally pressed the button that changes the recording format between SP, EP, LP, etc., you may not be able to fit the same amount of video on the disc that you were able to fit before. You can change the format by pressing the Disc Mode button on the remote - LP Mode will fit 3 hours worth of recordings onto a 2-hr disc and is considered a "medium quality" recording. Try changing the Disc Mode to LP and see if it will finalize the next disc that you record. The downside of this possibility is that the discs that you have already made that are giving you errors are not "fixable" - you will will have to re-record the shows to a new disc in LP mode.
-Tha Mp3 Doctor
I recorded from a mini dvd player and didn't finalize. I read this post and got the Recorder to finalize. It shows the time of the recording and when I hit play, it just has nothing on the screen. All seems to be going along as expected, and then there is no final product. thanks ahead of time for any help.
I am using Maxell 16x DVD +RW media. The ability to select edit disk and finalize is not available. From what i read using -rw disks means that you shouldn't have to finalize anyway. It will record just fine on +R media.
It plays back ok when in the player but now on my New Gateway PC with a DVD +/-RW dvd burner or in the home Unit.
Anyway to get this to finalize?
When I go to the Disc Edit menu, the Finalize option is no longer there... What is happening here?
How do I finalize the disk
Yes the edit disc menu is not highlited meaning you can't use it, to finalize disc. What the f...........
I too own a Magnavox MWR 10D6 and I am having trouble finalizing my DVD. What do I do?
i dont know how to finalize a disk
