Question about Farmall Cub Tractor Radiator
Ariens ST 724 impeller does not move under stress?
Moved some heavy snow today and then the impeller stopped working. No objects in the way.
Spins if I clear chute but boggs and does not have enough power to move snow out chute. Do I tighten belt? Does it have that capability or do I need to replace the belt. If so what is the belt #?
Thanks for all your help.
I have a old ariens ST724 snowblower engine will only run with full choke.
Posted on Dec 29, 2009
In heavy snow stop blowing snow
1 -Verify that all of your shear pins or bolts are in place. 1 on each auger and either 1 or 2 on the impeller fan.
2- Make sure all of the impeller blades are not bent as this will affect the throwing distance.
3 -Check the impeller bearing as it will lift if it is bad once snow is introduced into the machine.Remove the spark plug wire and verify that there is no tension on the impeller by turning it with a stick or broom handle. If it is safe reach through the chute hole and grab the impeller shaft and try to move it up and down, there should be little to no play.
4- Check your belt or belts. The belt should only deflect 1/2" with moderate pressure to be adjusted properly.
5- Check the condition of the belt, if the sides of the belt are glazed it may be slipping under load, if so replace the belt or try using a belt dressing spray.
snowblower belt adjustment
Jan 31, 2016 | Garden
Auger blades are spinning
sound like you might have 2 problems. If auger doesn't engage in heavy snow you probably just have ice accumulation inside the impeller. Dont try to engage until impeller is cleared of snow (shut off and unplug spark plug before cleaning) Second if blades are spinning than you must have hit something in your path and broke the shear bolt (about 2 bucks at hardware shop) remove the old bolt and replace it and it should work again if this is the problem. Good luck.
Feb 05, 2014 | Yard Machines Garden
1998 Porsche Boxster windshiled wiper stopped working
Could be loose wiper arm. Are the blades heavy. Too big of wiper blade will cause problems
Nov 15, 2012 | 1998 Porsche Boxster
The blower won't throw snow - especially heavy snow. Auger and impeller turn but bog down. Trying to replace belts, but there are no numbers or sizes on them. Are these generally available (say at a...
If the belts are intact, then NAPA or a hardware store should be able to replace them. If they are shredded, then you should order them from Ariens. Good luck!
Feb 01, 2011 | Garden
Hi, i have a 20 inch 12 amp yard works snow thrower. the problem i now have is under heavy load of snow, the impeler stops turning, but the electric moter keeps running. under a lite load it works as it...
Does the impeller have a clutch control so that the motor continues to run, but the impeller/auger stops? If so, then clutch travel adjustment should fix the problem. If there are no obvious adjustments to a clutch-less drive, then shifting the motor position should tighten the belt. If the motor position is fixed, then replacement of the belt seems to be the only option. Wear at the sides of the belt can cause slippage. Hope this helps!
Jan 09, 2011 | Garden
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
My ariens 824 wont go forward or reverse. snow thrower still works. wheels start to move a bit then stop
I would check your traction drive disc for wear or shredding.With low or little fuel in tank you can safely grab handle bars and lift machine up on it's auger housing.Then remove shield from under machine and inspect metal disc with rubber around it.If rubber looks worn you can get a replacement traction drive disc easily from most small engine repair shop's or go online and look for your nearest Ariens dealer.
Nov 18, 2009 | Ariens Garden
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens Snowblower Repair Facilities
Start buy checking the gear box to see if there is any cracks in the housing if there is then your going to need a new gear box assembly, sometimeswhat will happen is the auger will stop do to an object and the shear bolts don't break while the impeller is still triing to spin causeing the gears in the gear box to break.You can go to www.ariens.com, then go to parts,then click where it says click here to enter Parts Radar, you will need to have your model numberyou can get the break down for your machine which will help in dismantle and puting it back together you will also be able to get the part number for any parts you will need. If you need a new gear box get the whole assembly not the indivisual parts. any other questions please feel free to ask.
Dec 23, 2008 | Ariens Garden
Farmall Cub Tractor Radiator Logo
1,012 people viewed this question
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
john milligan
Are you a Farmall Garden Expert? Answer questions, earn points and help others
