Question about Bestec (ATX-250-12E) 250-Watt Power Supply
EMachines T2245 won't turn on, front light stays on
I am completely computer illiterate- so bare with me as I try my best to describe the problem-
My eMachines T2245 will not turn on. I've held the power button for multiple seconds and still won't do anything. However when I unplug the unit, the light around the power button stays on, AND a small yellow light right below it. Not sure what is going on. Read other blogs, and maybe a PSU might be what is needed?? Are they expensive and hard to replace? Any advice will help. Thank you!
  • 1,602 Answers
IT CAN BE MANY THINGS 1 UNPLUG SYSTEM FROM THE WALL, 2 REMOVE THE MEMORY AND REINSTALL THEM, 2
CHECK ALL CONNECTION INSIDE THE COMPUTER CASE AND THE OUTSIDE TO, 3 TO REMOVE A POWER SUPPLY IS 4 PHILLIPS SCREWS POWER CONNECTIONINSIDE CASE, REMOVE THE POWER FROM ALL OTHER DEVICE CAREFULLY AND TAKE IT TO YOUR NEARST COMPUTER STORE, SAVE YOUR RECIEPTS IN CASE IT IS NOT THE POWER SUPPLY PROBLEM, RETURN IT AND GET YOUR MONEY BACK.
POWER SUPPLYS SHOULD NOT COST MUCH, IFYOU ARE STRAPED FOR MONEY GO TO GOOD WILL AND HAVE THE FIRE UP ONE OF THE SYSTEM THEY HAVE THEY MAY EVEN HAVE A NEW ENPTY TOWER CASE LAYING AROUND FOR 30.00 DOLLARS.
CANDYMANGANDY
Posted on Jan 29, 2009
Emachine e627 won't bootup
You're probably going to have to get someone to physically look at this for you. eMachines are notorious for having trouble sometimes. However, since you haven't described exactly what it DOES and DOES NOT do, it's hard to tell. Good luck! :)
Jan 14, 2013 | eMachines E Machines E627 Laptop Computers
My desk top monitor want stay on
What do you mean won't stay on? Describe exactly what it is doing? When does it not stay on, when you press the power button to start the computer? You said it does not stay on, so that tells me that it comes on for a while and you are able to see things, right?
Mar 30, 2012 | E-Machines eMachines Desktop PC
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working. I was fine yestyerday. I put in hibernate and tried to cut back on today...
Remove the RAM and install it again and restart.....it will work if still not work then change remove RAM again and start your machine..it will give beep sound...if it will not give beep sound then understand your machine's mother board is faulty......
Sep 09, 2011 | E-Machines eMachines Desktop PC
How do I add memory to my eMachine T2245. I know that it takes DDR PC2100, but can I use 1GB, or do I need to add memory in pairs?
Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot, so a max of 2GB. Your computer does not support dual channel memory or ECC memory. You also do not have to install it in pairs. This would be ideal for you.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220029
It has lifetime warranty. Pick up 2 of those and max out your memory. You will notice a HUGE increase in performance. Memory upgrades offer the biggest bang for your buck.
Feb 15, 2010 | E-Machines T2245 PC Desktop
I have an Emachines T2245. I wanted to install windows 7. It told me that my machine was not acpi compliant. Do I need to update the bios and if so where can I get the file.
Intel.com has your updated bios, but i do not know if this will help. everything i am seeing is saying that your computer is not windows 7 compatible.
Dec 27, 2009 | E-Machines -T2245-CELERON-2.2GHz,80GB...
The PSU fan does not run, computer shutsdown.
Check the CPU fan, it may be faulty and causes the CPU to overheat and shut down.
Sep 02, 2009 | E-Machines eMachines Desktop PC
Monitor stays black
best guess is the monitor is bad. Try replacing the monitor first.
Dec 02, 2008 | E-Machines eMachines Desktop PC
Keep getting orange light flashing three times
well..you may find that having a more literate person around, could go a long way to helping you out.
May 03, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Emachine shut down
No, it's just the USB ports that are still being powered.
Totally normal in most new computers. Same thing with the PS2 ports.
There are jumpers on the motherboard that can change this if you really want. It's designed like that to keep things like you have powered for when you do turn it on and need them.
Apr 16, 2008 | E-Machines eMachines Desktop PC
Bestec (ATX-250-12E) 250-Watt Power Supply Logo
511 people viewed this question
Top Bestec Computers & Internet Experts
Allen Lightsey
Allen Lightsey
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
De ice
De ice
Are you a Bestec Computer and Internet Expert? Answer questions, earn points and help others
