Question about Konica Minolta PagePro 1350W Laser Printer
HELP WITH INK LINES DOWN THE SIDE OF PRINTOUTS
Each time I print a page on my Konica Minolta Pagepro 1350w, to lines of ink run down the side of the page. I have tried to clean the inside multiple times but I am still having the same problem!
  • Anonymous Dec 12, 2007
    I have the same problem with line runing down the middle. I have replaced the catridge but I suspect it s the transfer roller. where else could the problem be
  • 98 Answers
If the line is solid from top to bottom of the page, the problem can be in different parts of the printer. Try a different toner cartridge if you have an extra one.
Posted on Jul 27, 2007
SOURCE:
Konica minolta pagepro 1350w not feeding full page but get stuck at half page.
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 16, 2014 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta page pro with windows 7
I looked at the manufacturer's web-site:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=1350W
and you are correct -- there are drivers for 2000/XP, and for 95/98, but nothing for Vista nor Windows 7.
Find an old computer running Windows 2000 or XP, and connect the printer to it, and "share" the printer across your home-network.
Apr 07, 2010 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta Pagepro 1350 page count or Print Config sheet?
please go printer utilty option on your pc then you can print a testpage
Feb 10, 2010 | Konica Minolta PagePro 1350W Laser Printer
I have a Konica Minolta pagepro 1350W printer. I
Please diregard. Since I was using an aftermarket toner cartridge, I took a chance and bought an OEM cartridge and... voila... it's working fine. Apparently, all I had was a bad cartridge.
Oct 07, 2009 | Konica Minolta PagePro 1350W Laser Printer
Pagepro 1350w prints with streaks on left side
Hello sir; Not thing you can use forever if lifetime is out you need to change otherwise the streak line not go away.
May 13, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Only left side of page is being printed. Just had cartridge refilled as I thought the ink was low. Unfortunately, it still prints the same? What does this mean? Thank you.
check 2nd transfer roller or pc drum, open door when printing and check pc drum, if there is the whole printed page, then adjust 2'nd transfer roller
Jun 07, 2008 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta 1350w
If you're getting white lines, you are running out of toner, but if the lines are black, I believe the drum is the problem .Remove the OPC drum and check its surface for lines, if there are any lines, you can bet it will be printed on the paper.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Apr 25, 2008 | Konica Minolta PagePro 1350W Laser Printer
Konica pagepro 1350W
There is no cleaning sequence for the 1350w. I usually just pull the toner unit out and clean the roller, etc. Compressed air for the moving parts and hard to reach places. Best to do it outside.
Sep 05, 2007 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
158 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
