Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
Not Detected on PC
I have a Western Digital USB Hard drive Model WD1600U017-004 160 External Hard Drive. I used this for so many times, until such time it can't be detected in my PC or laptop. I checked on the device manager but the device is properly working but why is it the dive does not appear.
I need help ASAP. because my important files are there.
Hope to hear from you soon. Thanks.
Dads My WD 250 Gig worked fine till yday evening and suddenly it decided that it wouldn't work. In the Disk Management, it says not initialized and I am not able to initialize it either. Is it time to bury it for good?
    New Friend:
    Problem Solver:
  • 11 Answers
Maybe, your hard disk enclosure is broken already, but your hard drive is still functioning. You can open the enclosure and try inserting your hard drive in your PC if it's still working so you can save your important files there.
To open your enclosure, copy the link below and paste it in a new tab.
http://bitly.com/1JeWLLo
Posted on Aug 24, 2015
I found this on this site. in case you havent seen it. It worked for me. Try this:
When I disconnected my backup drive and plugged in a USB drive the other night, my Windows drive letters got all wonky. D: became G: became F: became H:, and a bunch of my shortcuts didn't work anymore.
But it's easy to reassign the drive letters of your choice to add-on disks in Windows. Microsoft says you should log on as an administrator, and from Administrative Tools in Control Panel:
Double-click Computer Management, and then click Disk Management in the left pane.
Right-click the drive, the partition, the logical drive, or the volume that you want to assign a drive letter to, and then click Change Drive Letter and Paths. Of course things can get wacky if the disk is in use - by your computer or another on the network - so proceed with caution, you drive alphabetizer, you.
How to change drive letter assignments in Windows XP [Microsoft TechNet] Read More: Windows, Hard Drives
Posted on Mar 12, 2009
I HAD Western Digital My Book Essential 1TB External USB 2.0 Hard Drive ON M PC AND I CONECT WESTERN DIGITAL MY PASSPORT AND RUN THE AUTO FROM THIS SOMETHING LIKE WD SMART.... AND NOW MY Western Digital My...
Your WD HDD have been attacted by viruses for your computer or outside computer where you used it last. Make sure that you have an up to date antivirus software, scan your computer or the external hard drive, explore your computer, go to tools - folder options under view files & folders select show hidden files and folders apply and ok it.
May 18, 2011 | Western Digital My Book Essential 1TB...
I lost the installation cd for my western digital external hard drive how can i install it without the cd
Without the model# of your drive, I can only get you as far as the Western Digital Support Downloads portal page (link below). When you get there, be a little patient using their site and track doen the driver download for your model. Download it by saving it to your desktop and then install it from there.
After that, you should be able to connect hte drive and start using it.
Regards,
MAGT
Oct 01, 2010 | Western Digital External USB 2.0 80 GB...
Western digital 100gb external hard
The model number needs to be verified. Can you please validate it. You can go to this site and validate its drive type http://www.support.wd.com/ enter the model number and look at Specifications. Most external drives that are older than 2 years are IDE though.
Jun 02, 2010 | Western Digital External USB 2.0 80 GB...
Western digital passport i/o device error
90% of the time this is a power problem. The USB port on the computer can not supply enough watts. Use an external USB hub that has a 5V power supply.
Oct 14, 2009 | Western Digital 250GB MyBook External USB...
Western Digital External USB 2.0 Drive sometimes won't connect
problems like these are usually because of the usb connections, if the usb connection isnt strong enough i.e getting enough power,
try it on another pc if you can see if the problem persists
Sep 09, 2009 | Western Digital USB 2.0 External Enclosure...
Western digital 320g elements portable won't work
Hey,
try connecting it o another computer and check
if not yet, use only the WD USB transfer wire supplied in the box.
because WD External HDD only recongize its own USB and none other.
May 03, 2009 | Western Digital Elements powered by WD 320...
My computer does not recognize my Western Digital (WD3200C032) External Hard drive. The hard drive orignally worked fine. Then one day 3 separate computers would not recongize when the USB was plugged into...
if u are using a external hard disk case with the normal hard disk
try connecting your hard disk with a new casing.
if it is made as a external hard disk change the cable .
because after a few time usage the cable will not be quite good as new.
After inserting the usb cable in your pc if it shows any warning
information, or any message just give me that too for exact solution
Dec 15, 2008 | Western Digital (WD3200JS) 320 GB Hard...
External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
May 11, 2008 | Western Digital My Book Home Edition 500...
Laptop usb hard disk
I've had this problem many times with external SATA hard drive plugged into the usb. My 120gig hard drive takes significant power to operate it. On laptops with a long cable to the usb, I get the Tick tick tick sound and the light flash in concert with the ticking. On laptops with short cables to the usb, the hard drive works. On one desk top, the hard drive doesn't work on the front usb but does on the rear because the rear has no cables. The usb comes off the motherboard. Conclusion? Most likely a voltage problem from longer than usual cables from the motherboard to the usb. One solution is plug the hard drive in the rear usb. Another solution is buy a more expensive cable linking the hard drive to the usb. Or buy a shorter cable. More expensive cable may have thicker wires that won't resist the current. But I do not believe for a minute that the hard drive is faulty. I've seen it too many times and it has never been a faulty hard drive.
Sep 15, 2007 | Western Digital 320GB MyBook External USB...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
758 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
