Question about RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Volume button tv turns off when volume button is pressed.
  • 74 Answers
The buttons on the board is probley leaking need to replace them.
Posted on Feb 20, 2009
My COby tv wont turn on.
I unplugged my TV for 5 minutes after 5 minutes I pressed the Power button on the side of the TV not the power button on remote for a full minute. Plugged the TV back in, pressed the power button and it turned on. Doing this essentially does a reset.
Dec 26, 2016 | Coby Televison & Video
How to reboot cherry mobile spark tv?
Here`s how to hard reset you Spark Tv
1. Turn off the your Cherry mobile Spark
2. Press power button, Volume down and home button at the same time.
3, Wait for a Spark TV logo then release power buttons and continue holding Volume down and Home.
4. Scroll down and select wipe data then press home button
5. Select reboot and your phone will be unlock but all files in the internal storage will be deleted.
or try this
SPARK TV cherry mobile HARD RESET too many patterns attempt solution
POWER ON + VOLUME DOWN BUTTON press together in 20 seconds or until the Android system recovery <3e> appeared
Press volume down to wipe data/factory reset then press power on
Press volume down Yes -- delete all user data then press power on
Press power on to reboot system now
After reboot HARD RESET was done
May 20, 2014 | Nokia E Cell Phones
Hi. Can you please tell me the correct code for the Curtis tv for Cablevision Remote? We have two remotes now, the cable remote cannot operate the volume or the power on/off tv, must use Curtis remote.....
Hello
Codes for Curtis TV with Cablevison remote control are:-
070 004 101 127 236 011 072 081 120 164
*Tip: The iO button will light on for 20 seconds. The
next step must be entered while the iO button is
on.
STEP2 Press the [INFO] button.
The iO button will blink number of times indicating the
number of each digit of the code number. Each digit is
separated by a 1 second interval of the iO button being
turned off.
Example :One blink, three blinks and eight blinks with
an interval of 1 second of iO button being
turned off, indicates the code number 138.
Note :Ten blinks is equal to the number 0.
D. Program the Volume Controls.
By following the steps below, the user can program
the volume controls (Volume UP, Volume Down and
MUTE) . The default volume control settings on the
remote control is TV volume control. If you wish you
can control the volume via your CABLE box, use the
following steps.
STEP1 Press the [CBL] button and the [SEL] button
simultaneously for 3 seconds. The iO button
will turn on.
*Tip : The iO button will light on for 20 seconds.
The next step must be entered while the
iO button is on.
STEP2 Press the [VOL +] button.
STEP3 Press the [CBL] button.
The iO button will blink twice to confirm the
programming.
To return to original state:
If you wish you can control the volume via your TV,
repeat the above steps by pressing [TV] in STEP3 .
OK.
Dec 23, 2010 | Curtis CM13102 13" TV
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
My sky remote control has recently stopped turning my tv on and off and also controlling the volume. I have encountered this problem before but after a day the problem has righted itself. My tv is a JVC....
Hello Rina
Please follow the steps below with the sky remote:
TV
RED + SELECT
TV
0053
press the volume button if this works press the SELECT button to save if not press TV then volume again. repeat this step until the volume works. Dont forget to press the SELECT button to save the code.
Hope this Helps
Cheers
Little Dish Fitter
Sep 18, 2009 | Televison & Video
The volume control won't work on my sky remote
for a toshiba tv,
press tv
press and hold select and red until the led blinks twice
type in 0 1 5 6
press the power button on the remote
If the tv turns off press select and hey presto you're done, if the tv doesn't turn off, press tv then press the power button and keep doing this until the tv turns off. When the tv turns off press select.
Nov 17, 2008 | Universal Remote Control Remote Control
How do I get the volume to work on my sky remote control?
SHARP TV
TV
RED + SELECT
TV
0093 (sharp code)
press the power button if this turns your TV off then press SELECT to save. If not press TV then POWER. repeat this step until it does turn your tv off remember to press the SELECT button to save the code.
Cheers
Little Dish Fitter
Sep 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
RCA 27F500TDV 27 in. TV/VCR/DVD Combo Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
