FixYa.com
Tags:
Microsoft Xbox 360? Elite Console
Xbox 360 flickers green and black on the screen (by 7 users)
posted by bezerker77 on Jul 25, 2007
I just connected my brand new samsung LN-T4061F to my xbox 360 Elite ... when I play movies or games I get the following intermittently... screen becomes black for a split second or it flashes bright green and goes back to normal... this happens regularly during movies and xbox games. I have xbox running in 1080p extended... Please help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by Guest, posted on Apr 18, 2008
i have the same problem (xbox, hdmi cable, 1080p, ln-t4061f)
Comment by jackiechiles, posted on Apr 10, 2008
I just started having that problem. After about 10 minutes of using my Xbox 360, most of the black color becomes green. I also have a Samsung 4061. Is it the Xbox or the T.V? I hope its the Tv. I have the extended warranty from Bestbuy and hopefully I can return it. I am using the regular av cables not the hdmi cables. Am i wasting my money if i buy new cables?
Thanx
Comment by RayFSC07, posted on Jan 05, 2008
I have teh same problem. I am using XBOX 360 Elite and Samsung LN-T4661F. At first I thought it was the cheap XBOX HDMI cable that came with the XBOX, but I replace with a Monster Cable and still experience the same problems.
Comment by aychung, posted on Dec 13, 2007
I have the same exact problem. I own a Samsung 4065 and my screen flickers green or goes black and the sound also cuts out sometimes. I'm not sure if it is my tv or if it is the xbox. When I turn the tv on and off everything is ok again. My xbox 360 pro was built 10/07 so it is one of the newer models. This issue is not limited to elite only
Comment by Guest, posted on Nov 30, 2007
Having the same issue with a Samsung 4065 and XBox Elite using HDMI. Sound will occassionally cut out too. Whitesox, I have no idea what you mean by your "solution" if anyone else knows what the issue is and how to resolve thanks!
Best Solution
posted on Jan 18, 2008
Helpful (85)
ax09001h
Rank:Apprentice Apprentice
Rating: 91%, 5 votes
Back again. There is thread on CNET about this as well. My TV has made it's third trip to the repair shop, and Samsung is definitely aware of this problem on 4065F and 4665F LCD TV's manufactured in 2007.
I tried multiple cables and multiple input devices (XBox360 Elite, PC DVItoHDMI, and Scientifc Atlanta DVR with HDMI) all with different cables, all with the flickering.
The only known solution is to have the main board replaced (this should still be under warranty (1 year)) if not they still might replace it. It would cost about 250 in parts and 250 in labor.
If they do not install it correctly (since the boards come from factory and need to be adjusted) the picture will be too dark. Tell them they need to contact Samsung to get the instruction manual for board replacement.
I got my TV back and it has shown no signs of green flickering or signal dropping.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 03, 2008
Thanks for Trying (70)
sirlylos
Rating: 70%, 2 votes
Problem solved....
I had the same issue myself up until last week and the problem hasn't happened since. I too was experiencing the immensely annoying flickering and stuttering but all you need to do is replace the HDMI cable....
check out play.com for cheap ones - it cost me £12.99 and it's all sorted now.
Solution #3
posted on Jul 26, 2007
whitesox
Rank:Wiz Wiz
Rating: 83%, 79 votes
If extended may mean 4:3, it could be your TV trying to reformat the image and sometimes just NOT being able to saty shiny at the 10000:1 contrast and keep up with the processing. Also: if you arent using HDMI you need to. Direct to the TV.
The last thing i can think of is if you are running Audio into the TV also, and dont have external speakers there could be some processing issue. Keep me posted on how this helps i have an HDTV and Elite so can try various things. Contact me!
Hope this helps!!!
Solution #4
posted on May 19, 2008
Not Rated (0)
DAF52
Rating: 100%, 1 votes
i had the same thing on my hitachi tv and it was my mobo in my 360. just got it back, working fine now.
Can you Help with these Video Game Consoles problems?
Lack of Audio output
I recieved an X Box 360 Elite... Answer This...
xbox 360 elite
i have no green light on my... Answer This...
problem with 360 elite
no green light on concel can... Answer This...
xbox 360 elite
having problem connecting... Answer This...
shipping and format
i want to known if you ship... Answer This...
6 Other Users Have The Same Problem - Continued
Comment by ax09001h, posted on Nov 06, 2007
I have the elite - and I have the same problem - also with a Samsung LCD HDTV. My brother has a similar Samsung LCD HDTV I ran it down at his house for an hour and did not see the same phenomenon. Not sure what to do just yet.
Repair Service
Find Video Game Console Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
