Question about RCA D52W23 52" HDTV CRT TV
D52w23 making loud whine
I have the one with the whine...it is coming from a black cylinder wrapped in wire near the flyback sticking up from the board...if you touch it on top it stops whinning....what is this thing and what can I do to make it stop?
  • RCA Master
  • 5,138 Answers
Either replace that part or try resolder,then put Glue on it from Glue gun.
Posted on Feb 13, 2009
I have the D52W23 RCA TV and it will turn on but no picture will come on the screen. when you turn it on it makes a churping noise every 2-5 seconds do you have any idea of what this could be?
You have may be two bad eletrolytic caps and a high voltage safety cap that are bad. And maybe a bad flyback. This is the common problem for this TV. Sorry!!!
Mar 01, 2010 | RCA D52W23 52" HDTV CRT TV
Flashes/blinks 9 then 5 won't turn on.
Check the CRTs . That model was notorious for laser like cuts right around the neck by the yoke. I just had one today doing the same thing. The CRTs are no longer available so the set is scrap. I hope that's not your case. Let me know.
Oct 20, 2009 | RCA D52W23 52" HDTV CRT TV
Remote works near the player within 4 inches and not beyond
open the remote control,they have 1 wire wrapped around a black cylinder ,you have to make sure it is not broken,if it is broken you can sawder it back together.
Jul 07, 2009 | Bose Lifestyle 28 System
Tv turns on then shuts off in seconds
unplug remove the back "CAREFULLY" slide the the plastic board assembly out do not unplug anything check near the flyback for a large grey capacitor check for burn marks underneath it if no check at the front of the same board inside one of the heatsinks for a swollen capacitor if thats not it you need a flyback and or horizontal output
Jun 10, 2009 | RCA D52W23 52" HDTV CRT TV
D52w23 rca makes an awful loud high pitched whine
This is a coil, now a NOISY coil.. It is a common problem, and happens often. The whine is caused by current passing thru the copper windings and making them vibrate! A commonly accepted repair for this situation is to squirt some regular old super glue into the copper windings and let it harden for a few minutes..Viola! no more whine!
Jan 28, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
36" RCA- loud whine/squeal when it is plugged in, otherwise no power.
The HOT Hortz output transistor has gone home, 99% of the time from a faulty IVHT (Flyback Transformer), very common on the ctc187cl* chassis. The factory Flyback is no longer available, I have had problems finding an aftermarket one to replace it with.
The HOT is a BUH517, but you can also use a 2SD5129. It is the transistor mounted on the siler heat sink with a metal clip rather than a screw, just in front of the flyback.....
If you replace just the HOT, most of the time you will get a rapid arc (27,000volts - BE CAREFUL!!!) from the lower (yoke) post on the flyback. If the flyback is shorted, It may also just burn out the HOT and go right back to "squealing"....
Good luck finding the flyback!!!
Oct 06, 2008 | RCA F32450 32" TV
D52W23 No picture only sound
You need a new flyback thats what the 3 blinks means. you can get a replacement flyback at the following link and they give free tech support so you can easially install it yourself you need flyback 259296 . Heres the link.
http://servicemanuals.vstore.ca/
Aug 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Big Screen making a loud beeping noise!
The beeping noise is usually related to the Horizontal out put transistor or flyback being faulty or one of the coils are loose near the flyback. If you remove the rear cover without touching anything can you tell if the beeping is coming from the large transformer with the red wire coming out of the top or is it coming from a black transistor on a aluminum heat sink.
Jul 22, 2008 | RCA P52930BL 52" Rear Projection...
Phillips 60PP9202
Try removing the back panel and try to power up the set and see if you can determine if the popping sound is coming from the flyback, in case your not sure what a flyback is it has a large red wire coming out of the top of it. If thats where its coming from let me know as you may need a flyback.
Mar 27, 2008 | Philips 60P8342 60" Rear Projection...
RCA D52W23 52" HDTV CRT TV Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
