Question about Lexmark X4270 All-In-One InkJet Printer
Lexmark 4270 Need status report after each sent fax
I am trying to set my 4270 to give me a status report after each fax sent. I do not have my set up manual and have not been able to figure out how to do this task. At one time, it was set up to do so but has lost that setting.
  • 382 Answers
All you need to do is push the option button, keep pushing option button to scroll through settings. you will find the print all function for faxes. Hope this helps. Good luck.
Posted on Jan 29, 2009
How do we set Samsung pro express M4580FX to do auto fax sent status and confirmation after each fax is sent (rather than printing reports)
dear
the sent report can be disabled at FAX SETUP.press menu and scroll to enter fax setup scroll to display report enter here to enable or disable the report. the sent report only display for short time after sending the fax. also you can take a print of journalreport.
Thanks.
Mar 02, 2015 | Samsung Office Equipment & Supplies
Fax confirmation
most printer in the market has the same standard setting for the fax.
u can set the report many types for many user's purposes, some people want to save paper, save ink/toner, so they dont need report if the fax is sent but only print report if the fax is not good(NG or not sent)
it can be set to:
report off--means report will be print out only if the fax is NG
report off+image--means report will be print out if the fax is NG + the image of the page that is not sent(so we know which page is not sent through the image)
report on+image-- every fax activities( sent or not sent) will be reported, which is not recommended
etc....
how to set is depends on your printer, just go to the menu "FAX" and look inside the menu.
Jul 08, 2014 | Epson Workforce 520 All-in-One Color...
How do i get the fax machine to give me a report of faxes sent that goes further back than just one week. i need a 30 day report.
The printer can only print 40 send logs and 40 receive logs. The information is limited to the number of faxes only. I hope I can assist you more on this matter.
Jun 22, 2010 | Lexmark X4270 All-In-One Printer
How do I print out a copy of a fax that has been sent 4days ago to confirm it was recieved
You cannot print out a sent fax, but you can print a report that give you a status of all faxes sent and received.
Press Setup, press 1
Press > (the right arrow) until you get to "Fax Log"
Press OK to select the report.
Please make sure to rate this solution. Thanks.
If you need a manual for your 4200, you can download it from
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&os=228&product=351125&lang=en&
Jan 04, 2010 | HP OfficeJet 4255 All-In-One InkJet...
Black ink cartridge in lexmark fax 4270
can you clarify? This is a fairly straightforward replacement.....Lift up the face of the machine, wait for the carriage to come over and fully stop moving, remove old cartridge and replace with new.....maybe more info on what is actually happening or not.....
Mar 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Remote fax error when sending a fax
Does it only happen going to one certain fax destination or every destination? There are some things to try on the Lexmark web site.
Go to www.lexmark.com and click Support->Technical Support. Type in 4270 in the 'Search by Model' box. Type in 'Remote fax error' in the 'Search the Knowledgebase' box. There is a topic called 'Problems Sending a Fax to Specific Fax Machines' that has some good general tips.
Steve
Feb 26, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X 4270 and Telephone Answering Machine
there are fax/phone switch that you can use to connect the phone and fax machine to use a single line. price range from $46 and up.
that is probably the best solution, other than switch the line manually.
Feb 23, 2009 | Lexmark X4270 All-In-One InkJet Printer
I need to print a sent fax report.
open both one-touch speed dialing panels--press DATA REGISTRATION >set> press search buttons to display REPORT SETTING >set> search to OUTPUT YES (This will print a report with every transmission, next option will give you the option of whether to print the first page of the document (yes) to remind you of what it contains)
that will give you a tx report with every fax sent..... if you want to see if a fax went through open both panels the press REPORT then press SET that will give you activity report
Feb 04, 2009 | Canon LaserClass 9000L Plain Paper Fax
FAX back
Do you mean to get the paper document back out of the machine? If it doesn't feed out automatically, it may need to be repaired.
If you mean that you want confirmation that a fax was sent, you can turn on the TX (Transmit) REPORT. This will print out the first page of a fax sent successfully.
1. Press the Additional Functions button.
2. Use the arrows to select FAX SETTINGS. Press the Set button.
3. Use the arrows to select REPORT SETTINGS. Press Set.
4. Use the arrows to select TX REPORT. Press Set.
5. Use the arrows to select OUTPUT YES. Press Set.
6. Press the Stop/Reset button.
The machine will automatically print an Activity Report after every 20 faxes (sent or received). If you want an Activity Report at any time:
1. Press the Function button.
2. Press Report button (number 03 on the left side of the keypad)
3. Use the arrows to select ACTIVITY REPORT.
4. Press the Set button.
Apr 17, 2008 | Canon PC-1080F Plain Paper Laser Fax
Need help on my lexmark x 4270
Fax does not require installation on the PC. Driver for Vista is here: http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:438:0:0
Aug 29, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
70 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
