Question about JVC HD-61Z886 61" Rear Projection HDTV
No video my hd-61z886 has sound no pic the lamp comes on so all is working i dont have any kind of video please help...........
  • 1 more comment
  • andre callegari Jan 29, 2009
    checked every input all is the same sound no picture..
    jvc hd-61z886 has sound no video checked all inputs tv lights up every thing works but no video,not even volume or menu displays.....
    this is a dlp power supply is good its a video problem
  • JVC Master
  • 19,396 Answers
F you get sound but not picture, clearly it is not PSU .
First leave the tv unplugged for one or two hours.
If you still no video on all conditions, then there is an internal fault.
Faults that can give you lamp on but no video are color wheel and DMD board .
Try to start The TV stand alone, if you get no video but sound you can try reinstalling the lamp, if still no luck , the video must be tested by a technician to fix the fault.
Posted on Jan 29, 2009
    President:
  • 1,214 Answers
Can you force any kind of a service menu to come up on the screen? We need to confirm if it's a "projection" issue, or if it's a signal issue.
  • 6,784 Answers
If you are running rgb cables, you will need to connect the video cable as well for the complete visual effect. i would check all my wires that involve sound and picture that are coming from the dvd/b-ray disc player. if you are running a digital set up then, you should do the same. you may have your sound wires plugged into the right socket but, without the video wire in the video socket, you will hear sound but, no video.
    Sergeant:
  • 221 Answers
You must determine if the loss of picture is loss of the raster (a high voltage problem) or loss of the video (a video processor problem). If there are raster lines but no picture you should be looking in the high voltage section for something that has failed; burned resistor, etc.
If it has raster lines, but no vidoe, you should be looking on the main big board around the jungle IC or any of the ICs for defective components. Of course, if it is an IC itself you will not see any defective parts; it has to be tested.
From your description of the symptoms, it seems the high voltage is the problem area as the three projection tubes flash on, but don't stay on......
  • JVC Master
  • 13,433 Answers
Check the source, try another input source for the video.
What does it mean when the blue lights keeps blinking when i turn it on
The "LAMP" LED light indication is on or flashing too?Yes,than the Lamp life are over.Must replaced the Lamp.
Nov 27, 2010 | JVC HD-61Z886 61" Rear Projection HDTV
Lamp needs to bereplaced,,,,, tv jvc model 61z886, need to know model of lamp i need and where to buy it
Google "DLP lamp" and you'll get many places from which to order lamps. Go to one of these sites and they should have a search box. Enter your model number and it should give you the part number of your lamp. Try several sites if the first one doesn't give you what you need to know. Once you have your lamp number you can shop the various sites for the best price. Note: You can buy your lamp complete (with the housing it comes in),..... or just the bulb and replace the bad one in the housing (cheaper)..... if you have the skills needed. If not buy it complete with housing. If you change the bulb only,.. don't touch it with your bare hands. Most bulb only packages come with rubber gloves.
Aug 24, 2010 | JVC HD-61Z886 61" Rear Projection HDTV
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
I have a green hue to my jvc hd 61z886 61 rear
Hi
More than likely the lamp ,go to JVC website and get the part number for your lamp,google it and all the suppliers will come up,usually easy to change for customer and may be in your operation manual "how to"
Jun 04, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
How to replace bulb
Hi, i have retrieved your manual. it has all instruction on how to replace the bulbs. Click here for your manual.
A fix ya rating would be most appreciated. Thanks:)
Mar 05, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
Hdm ps3
Have you went into the video setup on your ps3 and changed the resolution to 1080p?
Dec 19, 2008 | JVC HD-61Z886 61" Rear Projection HDTV
Hdmi cable not working
You have a bad main board it sounds like.
Jan 06, 2018 | JVC HD-61Z886 61" Rear Projection HDTV
JVC HD-61Z886 61" Rear Projection HDTV Logo
32 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
