Question about Mitel 5220 IP Phone
Reprogramming mitel phones for a different astreixs network
We had a network of IP phones that we purchased with Shift, they went belly up and I have no way to reprogramm these phones to work on our network Help!!
Do they have a we interface
How do I set them to factory default?
Hi Roland,
do you still have these phones? I work for a company in Edmonton and we can possibly provide voip services to the Mitel phones. If you still have this problem, email me at evers@shaw.ca
Martin
Posted on Apr 04, 2009
    Scholar:
  • 140 Answers
Interesting, problem.
First off, you are not going to be able to reprogram the ip phones yourself. I just completed training on a similar network. This is way too much information that you need to have access to in order to program them (ip addresses, mac addresses and so on). Don't think because you know how to set the IP addresses on a computer you can do the phones. It is a totally different process.
You will need to telnet into the phone server, etc.etc. You will need to know factory codes for programming and access menus. etc.etc.
But, it doesn't sound like your telephones are the fault here. It would be really strange for all of them to go out at one time. It sounds more like a network problem or server issue.
Try rebooting the phone unit (server) and then rebooting a few phones and see if the system comes back up. Also check the network connections from your server to network switch. Also try some different ports incase you have a switch port failure.
I can assure you that this is not something you want to approach by yourself. I have been doing moderate IT work for years and the IP phones are still a little confusing to me.
Posted on Jan 29, 2009
PC Port stops working
Class of service option disable PC. Port. Or the the hp port is not tagged/untagged to the wrong vlan.
Oct 16, 2013 | Mitel 5212 IP Phone
One way conversation on mitel phone on LAN network
What model of Mitel controller do you have? The 5312 works on several different controllers. Sounds like you have UDP ports blocked on you IP network. Please list your controller type and if you have a firewall/router/or layer 3 switching on your data switch.
Mar 27, 2013 | Mitel 5312 IP Phone
How do you reprogram mitel
You need a program called mitel db programming.
You will need to know the system IP address and the usernam and password.
Once on you can reprogramme any extension, as well as many other things.
Apr 17, 2012 | Mitel 5220 IP Phone
No dial tone on Mitel 5340 IP Phone. The message on the phone is DHCP: Discovery.
The network isn't configured properly for your phone to boot up. You should contact your phone vendor or system administrator for support.
Apr 05, 2011 | Mitel 5340 IP Phone
My IP mitel phone 5324 phone gives an error message option 128 missing
the DHCP server or your network switch isn't configured properly. I hope by now your network admin or vendor has gotten this problem resolved.
good luck,
Mark
Jan 27, 2011 | Mitel 5215 IP Phone
DHCP DISCOVERY - USING OPTION 128 ERROR ON PHONE
The network switch isn't set up properly.Contact your vendor or network admin for setting this up properly.
May 26, 2010 | Mitel 5215 IP Phone
Mitel 5220 ip phone locked out
Make sure that it is a Dual Mode 5220. If it is you can use it as a SIP extension. It wiill say it on the back of the Mitel phone next to the 5220.
If it is a dual mode phone you can purchase a sip trunk from a provider and then would be able to use the phone.
When you boot up the phone hold the blue super key while the phone boots, hit the no softkey till you get to phone mode. Hit yes it will allow you to change the phone from minet to sip. This should get you started in the right direction.
Jul 30, 2009 | Mitel 5220 IP Phone
Mitel 5212 for home use
No you cannot.
The Mitel 5212 uses propitiatory software unlike SKYPE which uses open architecture software. You IS Dept. could invest into a Teleworker Server and you could have all of the features of your office phone at home.
Jan 10, 2009 | Mitel 5212 IP Phone
How do you do a factory reset on the Mitel 5220 IP Phone ?
To Restore Factory Default Settings:
1. Press both Up and Down Arrow keys simultaneously while powering up the
phone. NETWORK SETTINGS? appears
2. Press NO until TOOLS & FEATURES appears and then press YES.
3. Press NO until RESTORE DEFAULTS? appears and then press YES.
4. Press CONFIRM. The phone resets with default settings.
Nov 25, 2008 | Mitel 5220 IP Phone
Mitel 5220 IP Phone Logo
312 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Kelley Hopper
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
