Question about Canon Pixma MP500 All-In-One InkJet Printer
I keep getting an error code 5100.
I cancell the printing and turn off the printer. I let it stay off for a while and turn it back on. Five pages later I get the error code again. I also just change the ink. All were low except the small back was half full. Now the small black is showing low after five pages.
    Problem Solver:
  • 5 Answers
By your description, you probably have read that the 5100 error means that the movement of the print head holder is blocked. I get this error occasionally and handle it by turning the printer off and then on. The last time it happened, I heard something like a belt snap. Try opening the printer top and seeing if you can gently move the holder. Are you hearing sounds from the printer that are new?
Posted on Feb 26, 2009
5C00 Error Code as well as yellow and green alternating lights
To fix this error is much easier than it looks. Unplug the printer power. Move the ink cartridge cradle to the left. Over to the right you will see a small pad about 1cm square. This pad and the area around should be covered with ink. Get a cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently. Squeeze the pad several times between your thumb and forefinger while inside the microfibre cloth to remove ink build up. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now.
Jan 14, 2017 | Office Equipment & Supplies
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
Prinnter not printing but showing 'put custom in manual tray'
There is still a print job in the queue. Place a sheet so it prints or kill the job.
Open Printers and Faxes. Open printer. Highlight jobs and Right click > Cancel, or Documents > Cancel.
For those stubborn jobs, Right click My Computer > Manage. Choose Services and Applications > Services > Print Spooler. Right click and stop. Then start. This may have to be done from the Print Server if it's network printer. Contact IT to kill.
Nov 09, 2012 | Office Equipment & Supplies
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Office Equipment & Supplies
Paper jams consistely and then continues to feed, even if only printing one page
check your paper size setting on your print menu. i had this problem when i set the paper size smaller than the printer is able to handle (3x5 card) ... i just switched to 4x6 and don't have any problems.
Oct 24, 2008 | OKI C5100n Laser Printer
Okidata Microline 30 Turbo dot matrix
The problem your having is a spacer motor. It's located under the carriage that holds the ribbon/printhead. The part number is 56513701. Available at Seattle Platen - Dale 1800-221-2388.
Here's a free copy of the Okidata 320T service manual that will walk you through testing and verfying before ordering the replacement part.
If this helped you, please hit me up with a FIXYA. Thanks.
http://www.feedroller.com/Store/Service%20Manual/SER320T.PDF
Aug 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printer won't recognize cartridge
I had the same problem. I'm not sure but I think I replaced the cartridges when the printer was on because I turned the printer off and removed one of the cartridges. When I turned the printer back on it recognized that cartridge but not the others. I turned the printer off again, rmoved all cartiridges and put them back in when the printer was still off. When I turned the printer on again I had no problems. So...try turning off the printer, rmove all cartridges, then put them back in and restart printer. Hope this works for you .
Nov 28, 2007 | Epson Stylus 2200 InkJet Photo Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
179 people viewed this question
old marine
old marine
