Question about Lexmark X5470 All-In-One InkJet Printer
Dont know hw tp get started with lexmark printer
I need to scan and dont know how to do it ?
  • Anonymous Apr 18, 2009
    i dont now how to get the printer started
  • charles raynor May 11, 2010
    Have you installed the software for your printer? Lexmark has always been good about step by step instructions for setting up and using your printer/scanner/etc.
    Problem Solver:
  • 15 Answers
First, I'm assuming you are using some flavor of windows, but if not this may not be completely accurate. I'm also going to use windows XP in any directions I give, but if you are using Vista, it will be pretty close.
There are a few ways to do scanning. If you have a favorite graphics application like photoshop or paint shop pro, you can scan directly into these apps using the "Acquire" option. This is usually done by going to File->Acquire in the application, and then selecting your scanner.
The printer also probably came with a software suite for scanning as well. If you go to Start->All Programs->Lexmark 5400 Series, you should see something along the lines of All in One Center (may be slightly differently named, but it's in this folder). Once you find this application, it should be pretty easy to scan.
As a third option, if you don't have a graphics application, I like to use, which is a free piece of software you can find at
Once you download, install it, and get it started, to scan a picture go to :
File->Acquire, and select "From Scanner or Camera"
It should present you with a selection dialog where you should see your lexmark AIO. Select it and it will bring up the scan dialog, where you can select Color Picture, Black and White, etc.
It is a good idea to hit the preview button first and let it find your picture. Then hit the Scan button and it will scan!
Hope this is helpful
Posted on Feb 07, 2009
I have my lexmark al in one scan,printer,fax hooked up to my laptop. I dont know how to scan pictures onto my laptop?
Hi there
for the canner to work, you have to install the printer with the CD that came with the printer. The installation software will setup the scanner so that you can scan by pressing the scan button on the printeror from the Lexmark Productivity Suite on your computer.
If you do not have the original CD, you must download the software from www.lexmark.combut be sure to download the full printer install, else the scanner will be installed.
Aug 27, 2011 | Lexmark X5470 All-In-One InkJet Printer
I have a lexmark x2600 and i dont know how to use it. whats the steps of scanning a picture
Using the printer operator panel to scan:
  1. Open the top cover, and then load an original document facedown on the scanner glass.
  2. Close the top cover to avoid dark edges on the scanned image.
  3. Make sure that the printer is connected to a computer, and that both the printer and the computer are on.
  4. From the printer control panel, press Scan button.
  5. Follow the instructions on the computer screen.
For more information, you can refer to the Lexmark X2600 User's Guide at
Jun 18, 2011 | Lexmark X2600 InkJet Printer
L don't know hw to fax on my lexmark x5650
hello. you can download a manual, so you can know how to use your printer. here is a link where you can download the lexmark x5650 manual:
select the>>> Download now
User Guide
Apr 15, 2011 | Office Equipment & Supplies
I installed the Lexmark x4530 and continue to get
Usually a cable is not hooked up or the printer port is not enabled.
If it uses a USB port it should auto detect the port.
If this is the case you will need to download a new driver from the Lexmark site that matches your operating system and install it.
Mar 28, 2010 | Lexmark X1240 All-In-One InkJet Printer
I using lexmark x215 i dont have cd but i installed drivery from lexmark site now my printer is ok but i dont know how to scan my docunments bc i dont have scan software where i scan my docunments so tell...
  1. Check the connections between the two machines.
  2. Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
  3. Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
  4. Close the printer's document lid slowly so the document does not shift position.
  5. Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
  6. Push the scan button. You may have to do this on the printer itself or on your computer.
  7. Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
  8. Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.StepAccept the scan and save. Return the original document to a safe location.
Feb 24, 2010 | Lexmark X215 MFP All-In-One Laser Printer
Cant copy or scan in my All in One Lexmark X6170.
You must have a CD.
Make sure the scanner is unlocked.
Try copying from ADF and scanner glass.
Oct 09, 2009 | Lexmark X6170 All-In-One InkJet Printer
I am first time using scanner..itz already installed now hw 2 use it
open the scanner soft ware on the pregrams folder and clock on scan- is it text or image and send the scanned data to the suitable app.
scan an image forst and see.
Aug 05, 2009 | Lexmark T632 Laser Printer
Cant scan
you will need the complete version of drivers.just click the link directly to get the complete version of drivers.,6970,204816596_653399443_331705383_en,00.html?tabId=7 ---------- in the link after it gets opened click the option ---- drivers&downloads --- --------- this will help.thanks.
Apr 10, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Cant figure out how to scan something
You can start scanning a document two dfferent ways--from the printer or from your computer. With either method, the first thing you need to do is place whatever you want to scan face down on the glass of the printer. Close the top cover.
If you want to do everything from the printer, press the button with the diamond on it. "Save Photo" should appear on your computer. You can then choose a name for the file and a location where you want to save it.
To proceed from the computer instead, you can start the Lexmark Imaging Studio. Click "Scan," select the Document option, and then click "Start."
That should get you started!
Jan 19, 2009 | Lexmark X2500 All-In-One Printer
Lexmark X5470 scanner problem
i had the same problem but if you open the Lexmark All-In-One center (can be found in start --> all programs --> lexmark 5400 series --> all-in-one center) and select scan (it will work)
if you dont have the program installed find your installation disk and when u re-install it, it should come up again
Feb 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
80 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
