Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I can not use my limewire it says that a firewall might be blcking limewire
U Just disable a firewall in ur system or disable antivirus protection if needed
Posted on Jan 29, 2009
Its not connecting to internet conection like limewire
do you remember if you agree to allow connection to this site (when you first installed it)./ if you can get to all other sites. Find your firewall and allow Limewire......if you cant find the allowance on your firewall uninstall Limewire and re-install this time allowing its connection
Jan 22, 2011 | LuckyWire
How come every time i download limewire in try to run it always say no connection.but when i ask other people they tell me to check my firewall but when i do lime wire be on the list so what should i do to...
There is many potential firewalls in the typical home that may prevent LimeWire from accessing the service.
The computer with LimeWire is the first place to check. If using Windows, there is a built in firewall with access rules. If you have a Internet Security Suite such as Norton 360, then it will need to be configured to allow access. Next is the router or firewall if you use one. The manufactured of the device will have documents on their website that explain how to configure the device for port forwarding. If this is the case make sure the ports associated with LimeWire are forwarded correctly.
After that may be the modem itself as many modems such as ones used for DSL are multipurpose devices and make use of a built in firewall & modem. Search your internet service provider for files related to access and configuration of your modem.
If all this is setup and it still does not work, your Internet Service Provider (ISP) may have blocked the ports specific to LimeWire and many other peer to peer file sharing networks (P2P) such as Bit Torrent. If the traffic is blocked by the ISP there is little that can be done.
Nov 20, 2009 | Computers & Internet
Firewall and limewire
Dear ckclee,
Just uninstall your new limewire and restart your computer. try to re-install the old version of your "work-fine-Limewire". If it doesn't work, the only way is go to start menu, browse the accessories, carefully choose "SYSTEM RESTORE". when it runnng.. pick the date which your computer work best, the restart it, remember... windows can only restore and set back time status not more than a week, according to my experience.
Good Luck
Mar 13, 2009 | D-Link AirPlus DI-524 Wireless Router
Limewire firewall
Hi amy_maguires
If you have recently got a new router, there would be a firewall on the router blocking the required ports for LimeWire to operate. To get around this, refer to your Router's user manual and find out how to access it and then unblock those certain ports. PLEASE NOTE: Do not attempt to unblock all the ports as this will increase the risk of getting your router and perhaps your computers infected with viruses.
If that is not your problem, you may be using and ISP (Internet Service Provider) that has blocked those ports as downloading music uses a lot of bandwidth which is a burden on them. If you have Satelite Internet, this is probably the case. You can try and resolve this by contacting your ISP and negotiating a price for them to unplock the port for you.
Please remember to give this solution a FixYa! rating.
Happy Easter
BearWeb
Jan 14, 2009 | Xincom Computers & Internet
My limewire says there is a firewall
please remove my firewall from limewire
Jun 16, 2008 | Norton Internet Security 2005...
Limewire
hi cassy13
never used it so found this might help you How To Setup LimeWire Firewall Settings -
riz.
Apr 21, 2008 | Adobe Photoshop 7.0 for PC
Firewall blocking access to LimeWire.com
no your linksys BEFSR41 is not having any firewall inside so its probebly some firewall or some antivirus on your computer which is not allowing limewire.com to work on your pc
you did n't mention which operating system you are using and which antivirus otherwise i can help in that manner
k try to search in your computer
your ROUTER is nothing to do with this issue
Mar 26, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Limewire connection
you need to find your router address from your manual (eg. 192.167.0.1). Then type this number in Internet Explorer address bar. If you did all ok at this point you should be opening browser control panel in Internet Explorer. Go to firewall page. Set Limewire software (you may need to use full path eg. C:\program files\limewire\) as an exception in ur firewall.
cheers
Feb 22, 2008 | Belkin (F5D72304F5D7000) Router
Open a port for a certain program
hi mike,
this router has its own firewall, although i don't think its a good idea to turn off the firewall
google the port that limewire uses and then use portforwarding on the router.
you can start by turning off the firewall on the router to see if it works. if it does then perrhaps just allow limewire to passthrough your firewall at the router.
good luck
smeags
Dec 31, 2007 | Linksys Wireless-G WRT54G Router
Firewall ?? I cant get Limewire back....
Find the IP address of the modem, it should be on a label on the bottom of the modem or in the owners manual that came with the modem. Then open internet explorer, in the address window, type > http:// then enter the IP address next to the // then press the enter key, you will see the home page of the modem, logon to the modem at this screen and make the change to the firewall to allow Limewire. BPCS
Dec 14, 2007 | Toshiba WRC-1000 Router (PA3227C1ETC)
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
88 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
shaun taylor
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
