Question about Philips Magic5 Voice DECT Duo - Fax / copier - thermal transfer - 50 sheets - 14.4 Kbps Plain Paper
Faxjet 525 will not send faxes
I have just bought a Faxjet 525. I set it up correctly it said. It prints and copis documents OK.
When I follow the instructions to send a fax it dials, then beep beep beep then stops beeping and does nothing else.
It consistantly does not send faxes. It says 03 reciever does not answer wich ever number I try to send a fax to.
However I can sucessfully send faxes from my computer to the same numbers. I tested this.
How do I get my Faxjet 525 to actually send faxes?
  • 2,120 Answers
It is never getting a dial-tone. Phone line should be plugged into the LINE port.
Posted on Jan 29, 2009
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
I'd like to refill the ink cartridge on my Philips
Yes, some have a chip on the cartrige unit, they cannot be reset.
Buy a new unit.
Sometimes using competitve ink in this machine can cause other problems.
The copies are light with background and with streaks, also sometimes the toner might be spilling below the developer housing or copy cartrige unit.
Good luck
Oct 14, 2009 | Philips Office Equipment & Supplies
How do i set up the fax to print a confirmation sheet when it sends something?
Try this:
Press the Setup button (it might be the sign of a monkey range)
  1. Press the Down arrow (c00844971.gif ) to highlight Print Report , then press OK .
  2. Press the Down arrow (c00844971.gif ) to highlight Fax Confirmation , then press OK .
  3. Press the Down arrow (c00844971.gif ) to select one of the following options in the table below, then press OK
On Fax Send Prints a fax confirmation report for every fax you send. On Fax Receive Prints a fax confirmation report for every fax you receive. Send and Receive Prints a fax confirmation report for every fax you send and receive. Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
Select the one you would like to choose ;
For further help click on the following Link:
Regards Soumajit
Sep 21, 2009 | HP Photosmart C7280 Laser Printer
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
"waiting for report" /won't copy
I experienced this problem when "Fax Setting -> TX Setting -> Print Report" is configured before you send out the fax.
After your Fax was sent, and the message "Waiting for report" appear forever and does not leave.
It is because your INK Level is Low and your have set "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report will not be printed out due to ink level is low.
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed out immediately, the message disappear.
Apr 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Fax confirmations
i have read the manual end to end and I don't think you can.
Only thing I see is this.
Customizing your settings using the Lexmark Fax Solutions You can adjust the fax settings in the Lexmark Fax Solutions. These settings apply to the faxes you send or receive.
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  3. Click each tab and change the settings as desired.
  4. Press Save Settings after you finish your updates. Nothing is saved until you press this button.
  5. Click Close.
The following table contains the Setup and Settings tabs for the Lexmark Fax Solutions.
On this tab
You can
  • Enter your company name and fax number.
  • Enter your name, company name, phone number and address as you want them to appear your cover page.
  • Select a cover page for your fax.
  • Choose to use error correction.
  • Choose to use fax header.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report
Select when to print an activity report is the only close item I can find. Nothing whatsoever about a confirmation report.
Feb 25, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I bought philips faxjet 335, tx error
sounds like your communication board is out or your phone line is not working when you unplug your line and put a phone on it can you get a dial tone? then your fax machine is probably broke
Dec 14, 2007 | Philips FaxJet 375 Plain Paper Inkjet
FaxJet 335, tx error
call the number manually . and does it answer with a warble immediately or does the phone ring a lot and then answer.
your timeout may be set too short on the sending fax setup.
Philips Magic5 Voice DECT Duo - Fax / copier - thermal transfer - 50 sheets - 14.4 Kbps Plain Paper Logo
584 people viewed this question
Top Philips Office Equipment & Supplies Experts
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
