Question about Kenmore 73952 Gas Dryer
Kenmore 70 series dryer shuts off and won't restart
I have a Kenmore 70 series electric dryer. It starts fine and seems to be running normal but shuts off after about 3-5 minutes. It will not start again right away. The dryer does not make any funny noises. Could it be that the vent is plugged?
  • 1 more comment
  • jenifrmac Jan 30, 2009
    my dryer will shut off after 15 minutes or so and beep 3 times. I can usually restart but it will not run long. I have check the vents inside and out. Cleaned out all lint. Tightened all visible connectors and inspected cord. I do not know how to remove the panel to check the unreachable connectors. I ran the factory test and all were ok. The dryer is about four years old. HELP
  • amanda_ann20 Feb 28, 2009
    My dryer will run for about 5 min and then shut off, and it trips the breaker. It will start again after i take care of the breaker, but then it shuts off again after only a few minutes. It is very frustrating and almost impossible to get anything dry.
  • Anonymous May 10, 2009
    I had the same problem. I checked the motor and it was packed full of lint and dirt. I cleaned it all out and it seems to be working fine now
  • 65 Answers
IT SOUNDS AS THOUGH THE MOTOR IS OVERHEATING AND SHUTTING ITSELF OFF. THAT IS ABOUT THE ONLY THING ON THE DRYER THAT WOULD SHUT IT OFF AND NOT ALLOW IT TO START AGAIN RIGHT AWAY, BUT LET IT START AFTER A WHILE. MAKE SURE THE MOTOR TURNS FREELY. IT SHOULD NOT DRAG OR HUMM WHEN TRYING TO START.
Posted on Jan 28, 2009
  • mrrandyhopki Feb 05, 2011
    is this fixable? is there access to the motor that I can check to see if there is lint or dirt
  • Kenmore Master
  • 4,655 Answers
It is possible that the vent pipe behind the dryer is blocked or clogged with lint. Check this first and let me know if this solves the problem.
I'm betting its in the circuit breaker. One is it alumina wiring? If so it may need an Anti-Oxidant Joint Compound. Two the screws for the wiring, may be not very tight. Turn off the main switch and tighten the screws all the way down. If this doesn't fix it, replace the circuit breaker.
Posted on May 13, 2009
Kenmore series 80 heats and turns fine but stops after 30 minutes or so at any heat setting
Does it restart after it cools down? If so your motor may be overheating and shutting down.
Jun 20, 2012 | Kenmore series 70 80 90 Dryer Motor...
Kenmore 70 Series Electric Dryer will not start
It sounds like the hi-limit thermostate and/or the thermal cut-off is what is causing your dryer to shut down. Basically it's over heating. You should replace these two items togeather. Also the thermal cut-off will be triggered by a grounded out heating element. Here is a diagram of where these items are located. hope this helps
Figure W-6: Dryer Rear Access
Feb 27, 2012 | Dryers
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
Nov 24, 2017 | Kenmore Dryers
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
Kenmore 70 series dryer makes buzzing noise and stopped working
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Kenmore 65942 Electric Dryer
Kenmore Electric Dryer 70 Series
your motor is over heating and shutting off.you need new motor.
Mar 11, 2009 | Kenmore 65924 Electric Dryer
Kenmore 73952 Gas Dryer Logo
1,144 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
