Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ice maker isn't working
We just recieved a 1 year old side by side Whirlpool refridgerator and since wee installed it the part of the ice maker where the fingers push the ice out of the ice tray stays up. It also has drinking water that you can get out of the door and it works. I have pushed the on and of arm up and down ( of and on ) but that has made no difference. Thanks for your help!
  • jathky Jan 30, 2009
    The problem corrected itself after an period of time. Thanks for the help!
    Scholar:
  • 140 Answers
The arm should be in the down position for the ice maker to work.
You should also check the electrical connection at the rear of the ice maker and make sure it is plugged in all the way. Sometimes you have to remove the ice maker to check the connections. It just depends on the model. If you need to remove it check the electrical connection you will see 2 silver screws about the fingers you are refering to (on the fridge wall). You will need to remove these and sometimes the will be wall screw on the bottom of the ice maker as well. The ice maker will drop out as one unit and you will see the electrical connection in the rear.
Make sure the plug is seated properly and reinstall the ice maker with the 2 or 3 screws. Make note to that your little plastic fill tube in inside the ice maker when you reinstall.
If you still don't have ice in 24 hrs. then you may be due for a replacement ice maker. partstore.com will be one of the cheapest place to order a replacement. Just enter the model of your fridge and it should pop up the replacement maker in a parts list.
You already know how to replace it yourself.... 2 or 3 screws. easy.
Posted on Jan 28, 2009
  • 410 Answers
The fingers should "normally" be in the 2 o'clock position facing the front of the icemaker. what we need to do is remove the front cover of the i/m look at the big gear in the center of the gear should be 2 clips that hold the gear in place. sometimes this clips will either break off or become compressed and then it doesnt allow i/m operation. the part is very easy to replace your self you need pt#8201515 that can be purchased thru a local appliance parts supply house or online thru  some place like sears.com. good luck peyton..
  • peyton thompson
    peyton thompson Jan 30, 2009
    Just wondering if you were able to get your icemaker fixed? I like feed back to make sure I'm giving good advice. please message me with any questions thx for using FixYa.com Peyton
Newly installed ice maker two days old, not dropping ice, frididaire refridgerator
Ice maker under warranty have them look at it will not cost you anything.
Aug 29, 2014 | Kitchen Appliances - Others
Freezer works ice maker leaks water into freezer compartment. Refridgerator cranked up all the way cold and throws warm air not cooling food it is 5 years old
sounds like its set to high on the cold selection, and it needs to actually defrost , setting the freezer to colder much of the time will worsen the problem, if you can unplug it for a day and let the machine defrost ( deice) then it will be able to actually function better, Ice causes the functions to not be able to work properly. the ice maker leak could be caused by the limit switch being frozen , remove the tray and make sure that the unit isn't clogged with ice, if it is,, leave the tray out while you have it unplugged, and it too will fix itself once the ice is removed
Jul 20, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Whirlpool Side by side Ice maker
check water valve for ice maker how old is the ice maker is more than 3 years then it might need replacement as well
Nov 03, 2008 | Refrigerators
Whirlpool Gold Side by Side Refridgerator GS5SHAXNTOO "Not" making Ice
this is a very broad problem. you have issues with your ice maker. it could be the solenoid that supplies water to it. it could be turn off, it could be the laser sensor malfunctioning. it could be the receiver of the laser. it could be the gear that harvest ice is froze up. or the heater to melt the ice if it has one has gone bad. or it could just be a stuck ice that would not come out of the ice maker.
you can remove your ice maker, thaw it up if there is ice in the tray. then install it back and observe.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Whirlpool GD5SHAX Side by Side...
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Whirlpool side by side refridgerator model GS6SHE*N*O, icemaker won't produce ice. Watter line is okay. This is only 6 months old.
make sure your ice maker is turned on and if it is a new install than it will take about 24 hours for the first bin of ice witch you will need o throw away because it is like the first snow the first ice that comes out will have the dirt and things that are in the line.filter and ice maker.
Aug 22, 2008 | Whirlpool Refrigerators
Broken ice maker
Make sure icemaker cycles. If it is most likely bad water valve
Jan 05, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
238 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
