Question about Brother HL-5250dnt Laser Printer
Can't print - paper light is on
My printer won't print and the paper light is on. There is no paper jam anywhere, I pulled out everything and can't find a jam, and both trays are full enough. I am unsure why I cannot print!
  • 3 Answers
Turn the printer off, count to ten, then note the light sequence ie: flashing organge solid orange, flashing green or solid green
Posted on Jul 25, 2007
  • Anonymous Jul 25, 2007
    Sorry...after turning the printer off and counting to ten, you need to turn it on then note the light sequence...
SOURCE:
Printer has error code H3-30 that wont clear with the #*C* code and will come up with a paper jam error. The last thing that was being done was a 2 side booklet was being printed and the last page...
Check the follwing portions
1.Paper Feed Rollers
2.Drum/assemly unit
3.Fusing Unit.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
May 25, 2011 | Sharp Office Equipment & Supplies
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Lexmark x2600 printer
Pull the tray out at the bottom of the printer. This is causing the printer to think it has a paper jam. It is simply the paper feed button.
Any other issues email me at [email protected]
Feb 21, 2009 | Lexmark X2600 InkJet Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
Mf8100 keeps displaying paper jam with red light flashing have pulled everything i can possibly find. can not find any jammed paper anywhere.
i used a bit of strapping cable and slid it up between where the paper first goes into the printer from the paper tray and found there was a bit of paper there. that fixed the problem.
Oct 01, 2008 | Canon Office Equipment & Supplies
Brother 5250
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
  • May 27, 2008 | Brother HL 5250DN Laser Printer
    Paper Jam & Flashing Light
    take everything out and look at all the rollers and printer path and look in the back of the printer
    Jan 15, 2008 | HP LaserJet 1320 Printer
    Epson Stylus CX8400 Paper Jam Error
    I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
    Dec 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
    MF-8170C REC. PAPER JAM and Open Cover
    Get a thick piece of paper and feed it in to the printer following the paper path the best you can until you get the piece of paper you can't see out of it.
    Oct 16, 2007 | Canon imageCLASS MF8170C All-In-One Laser...
    Brother HL-5250dnt Laser Printer Logo
    289 people viewed this question
    James Cagle
    James Cagle
    Jim Keysor
    ctnozil
