Question about Oster 12-Bottle Wine Cellar - Black
Oster Wine Opener---4207
Hi. My son gave me the Oster wine opener model 4202 for Christmas. We used it about three or four times and it started to make a very strange noise and then it quit. I have no information as to where he got or how to get it replaced. I think it was a defected wine opener and would love to have it replaced. Please give me some details about where to ship it or how to handle this problem. I live in Peachtree City, Ga. 30269.
Thank-you very much,
Amy Lambert
    President:
  • 1,214 Answers
Hello Georgian!
We have a friend who lives at Berkly Lake, and we went to a wine boutique if you will over near her house. I think they would know who services that unit. I can not think of the name of the store though, but it was pretty close by (3-4 miles) in a small business strip center. I know your close by, being in Peachtree.
Alternative, is to find a Oster appliance repair center. There has to be one in the Atlanta area for sure. Or really, any appliance place that services refrigerators. Heck, I (with my wife), it's her best friend) would come do it for the price of a plane ticket. Our friend could vouch for my knowledge.
Posted on Jan 28, 2009
How do I change batteries in my Oster wine opener
Which type of opener do you have? If it's the rechargeable type then you're outta luck. The typical
Oster Wine Opener lasts for about three years before it needs replacing. The irreplaceable, rechargeable batteries give out long before the mechanics of the opener.
Sep 04, 2017 | Furniture
Wine opener won't recharge
Do you really need an ELECTRIC WINE BOTTLE OPENER?
I've been using all my life a manual one, never had to rechage it.
May 02, 2015 | Oster Cordless Rechargeable Electric Wine...
Food network electric wine opener will not open
Take a look at this review and see if you are missing something in its use. Basically, put in charger base, connect transformer to the mains and charge for 8 hours. Remove the foil from the bottle top, put the wine opener on top of the bottle and press the button.
Oster Electric Wine Opener Review
Feb 23, 2014 | Sunbeam Oster Electric Wine Bottle Opener
How to remove cover from waring pro wo50
A broken cork was stuck up inside my Waring Pro Wine Opener. Model WO50B. No amount of maneuvering could get it out. I removed the two small screws holding the silver part of the opener on. After that was off I could see two more screws and I removed those. The unit still would not come apart. I noticed that there were four oval shaped rubber plugs up on the black part of the unit. I pried the ovals out with a wooden skewer. That exposed the other four screws holding the long part of the unit together. Once I got those out, I gently pulled the two sides apart about an inch. I could have pulled it completely apart at that point (I think) but from there I was able to free the broken cork from the big internal cork screw. Everything screwed back together fine and the unit works again.
Nov 20, 2013 | Waring Pro WO50 Cordless Wine Opener
Oster wine opener sticky rubber surface
Did anyone have an answer to this? I have had the same problem. I like the opener, but the parts of the rubber surface that are not usually handled get quite sticky. Any thoughts on preventing this, or if not on removing the stickiness?
Jan 04, 2013 | Sunbeam Oster Electric Wine Bottle Opener
I have an Oster Electric wine opener. I have half a cork stuck in it that won't come out....any suggestions??
Use a screwdriver (or whatever) to push the inner ring at the opening as far inside the appliance as you can. It is a black piece with a spring action that has plastic molded ridges inside. The ridges on the inner edge of this will grasp the cork. Then, while you are holding the inner section in place as far inside as possible, push the button to operate the opener and the cork should come out as it normally should. I had half a cork stuck up there, and this just worked perfectly.
Feb 21, 2011 | Sunbeam Oster Electric Wine Bottle Opener
A cork is stuck in my Oster Electric Wine Bottle Opener.. It spins and spins but will not move up or down. How can I fix this?
We had the same problem, and we took the thing apart, unscrewed the cork from the corkscrew and put it back together. You have to make sure you line everything up properly inside, though. There are contact points that need to be lined up on the inside.
Dec 28, 2010 | Sunbeam Oster Electric Wine Bottle Opener
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Fan doesn't work on oster wine cellar
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Dec 30, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 12-Bottle Wine Cellar - Black Logo
492 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
Charles T Nevin
Charles T Nevin
Are you an Oster Furniture Expert? Answer questions, earn points and help others
