LE DISPLAYING WHAT CAN I DO TO FIX IT
  • Mark Egan May 11, 2010
    Please provide the make and model number of the washer.
Le light on lg tromm wm2277hw
Posted on Apr 09, 2009
My machine cannot spin and drain water, it keepson displaying the LE sign which I have investigated to be unclosed lid signal. So how do I fix this problem
If the lid is closed and an LE error is displayed, the lid switch may be defective and will have to be replaced.
May 04, 2016 | Washing Machines
Epson workforce wf7620 error code 0x9D
I have a WF-2650 and the printer is displaying error code 0x9D. Does anyone know how to fix it?
Mar 04, 2015 | Epson Office Equipment & Supplies
I have a Samsung dishwasher that is displaying and LE error. What is it and how much to fix?
Oh no! LEaking error! Could be drain pump, or drain hose (most common). Cound be inlet port or the main pump. But it will probably require a professional to determine the cause and to repair it, because Samsung dishwashers are very difficult to work on and repair.
Sep 25, 2014 | Samsung Dishwashers
Load never starts and goes into alarm displaying LE
problem with the D D motor. kindly check hole sensor..
Feb 03, 2014 | LG WM2487H Front Load Washer
My LG front load washer is displaying an LE status. wHAT COULD BE THE PROBLEM?
the fault code LE means that your hall sensor is faulty or your motor is faulty. the hall sensor is attached to your motor. please reply 4 more help if needed. i can guide u thru the repair. good luck.
May 04, 2010 | LG WM-2277HW Front Load Washer
I have an LG WD 3243RHD washing machine/dryer combo and it is displaying LE. Is there anything I can do without calling a repairman?
LE on this machine indicates a motor error. The connector in the lead wire assembly is not connected to the connector of the stator assembly. You need to reconnect or repair the connector. Also, it could mean that the Hall Sensor is defective and you may need to replace the Stator Assembly.
Nov 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Displaying LE
Lg has a water pulsator which rotates while filling up with water. If pulsator is faulty, you will get this LE indication. Pulsator is found on bottom left hand side of unit when cover is removed. 2 clear water pipes are connected to it and there is a small plug in that has 2 wires. Remove plug in first then remove from the pipes.
Sep 21, 2009 | LG Washing Machines
LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Mar 14, 2009 | LG WM1814CW Front Load Washer
LdF7811ST LG DISHWASHER
LE stands for "Locked Motor". It means the main pump motor is bad.
Dec 07, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
New washer not washing
Unplug the machine for about 20 minutes so the computer can reset. First load?? Machine is under manufacturer's warranty get hold of the company who sold it to you - ask for a replacement.
Sep 15, 2007 | Washing Machines
Washing Machines Logo
121 people viewed this question
Top Washing Machines Experts
