Question about Panasonic Panafax UF-890 Plain Paper Laser Fax
When received a fax, there is a black shade on one side of paper
When I received a fax , there is a black shade area on the received paper. How can I fix it.
Thanks,
Jon
  • dcdethlefsen Mar 09, 2009
    WE HAVE THE SAME PROBLEM, HOWEVER, WE TRIED CHANGING THE TONER CARTRIDGE, AND THE THE DRUM OF THE NEW CARTRIDGE WAS CLEAN WHEN FIRST INSERTED, BUT NOW HAS THE SAME VERTICAL STREAK AS BEFORE, EXCEPT IT IS NOW ON THE EDGE INSTEAD OF IN THE MIDDLE OF THE PAGE. COULD THERE BE ANOTHER CAUSE, OTHER THAN THE TONER CARTRIDGE, THAT CAN BE CAUSING OUR PROBLEM?
    Genius:
  • 2,120 Answers
Take out the toner cart and turn it upside down. Swing away the drum cover. The drum should be clean, if not replace the toner cartridge.
Posted on Jan 29, 2009
Sharp UX B700 when sending fax the receiver received a black page.
Dear
Pl. make a copy on your fax machine, if its ok, then your fax machine is OK. else your scanner and related part may defective. However this may tested after SHADING ADJUST done on service mode.
Thanks.
Feb 25, 2015 | Sharp Office Equipment & Supplies
My intellifax 4100 has a wide solid black bar approx 1 1/2 wide down the entire right hand side of the page of faxes that I send. (faxes that are received by others). The machine works perfectly in every...
Here is a list of possibilities.
1. The scanner glass is very dirty on one side. (the area the paper paasses over.)
2. The laser scanner lens is dirty on one side
3. Look in the bottom of the machine and locate any mirrors and clean with a dry soft cloth.
You will need to remove the drum and toner to do this.
Feb 23, 2011 | Brother IntelliFAX 4100 Laser Fax
When faxing a paper and the recipient receives the fax, their copy has a wide black lines down the side....if we make a copy, it has wide black lines down the side....we have replaced the drummer we've...
FIRST I would check the scanner glass again you can test it by asking for a report to be printed..ie tx REPORT.. if this dowsnt have a line on it the problem is either the scanner glass or at worst the scanner unit it self.. I would double check the glass.. get a soft cloth and some glass cleaner on it and give the glass a good rub over. do you have the lines on incoming faxes .. if not the glass or scanner unit is the def area to be looking at, Luck A
Aug 27, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Black streak down right side of outgoing received fax
clean the scanner, it may have white out or some other obstruction blocking it
Jun 02, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
I have a Brother Fax 2850. When I send a fax the receiver has advised me that there is a vertical black line approx 2'' thick which blocks out some wording. How do I fix this?? Many Thanks Heather
Something is jammed in or covering the optics.
Check the area where the original document is placed for faxing.
Open this area and clean any liquid paper, sticky tape or staples covering the optics.
Test by making a copy. When the black line on a copy goes away the unit is fixed.
If the receiver is still getting this black line then it is probably their machine and not yours.
Send a fax to this number. 1300 368 999 It will send you back a copy of what it receives.
Nov 17, 2009 | Computers & Internet
Dark vertical lines
You have to clean the scanner.Open the dock feeder area,and make sure the scanner glass is clean sometimes the glass look clean but just a smaal dot on the glass can cause a line.Clean also the white area above the scanner.The white area above the scanner help for shading operation of the mchine.Make sure you clean with a sullotion that can remove ink but not damage plastic.
Feb 18, 2009 | Brother FAX-8070P Plain Paper Laser
Receive a black copy
scanner problem. if you receive faxes that are good. the scanner is used when you copy or send. Lawrence
Feb 26, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
ETRIX MAY DISPLAY IS SHADED BLACK IN NATIONAL FOREST AREAS
You can adjust the CONTRAST setting on the GPSr unit. This should help.
Dec 07, 2007 | Garmin eTrex Vista Cx GPS Receiver
Paper Jam message
There are a couple of sensor flags in side the machine and also the document feeder area. Little black levers that flip and trip a sensor. Make sure they are all moving freely. There is one or two in the doc feed area. One inside the paper feed area. One or two in the ribbon area.
Apr 19, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Panasonic Panafax UF-890 Plain Paper Laser Fax Logo
85 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
