Question about HP Color LaserJet 2600n Printer
I am getting stripes on pages printed on 2600n
I can see stripes or deposits on transfer belt (correct name?) What is a safe way to remove the deposits?
  • masterdivert Feb 01, 2009
    Thank you very much for your directions --sounds like this would take care of the cause of the deposit on the transfer belt, what about cleaning the belt itself - the deposit is stuck more than a vacuum would remove. Is there some way to get a manual on this printer?
  • 55 Answers
You can use a toner vacuum if you have one if not you can get one at office max or a store like that. make sure you turn off the printer first, if you can take out the developer and drum section do that and then be very careful and vacuum.
Good Luck
Posted on Jan 28, 2009
Hp 2600n line
after you have printed a few pages switch the machine off just as the paper leaves the fuser. then open the front cover and take a close look at the image transfer belt ( black plastic conveyor type belt)
use a torch shone accross the belt to better light the error- if you can see these Green/yellow/cyan lines on the belt then theres a good chance its coming from the toner units- ( also try print quality troubleshooting pages in the menus under diagnostics.look at the individual colour pages and look for any lines or Uneveness about the shaded colour) replace whichever toner is not printing correctly
Jan 22, 2014 | HP Color LaserJet 2600n Printer
I got an inexpensive used HP Color Laserjet 2600n that needs a new ETB belt as it's putting vertical stripes on the pages. Do I have to purchase the whole assembly or can I get just the belt. Also, where's...
You have to buy the complete transfer belt assembly. I used to buy mine from express terminals but haven't used them for a few years, I would buy oem a lot cheaper and work just as good.
Oct 19, 2013 | HP Color LaserJet 2600n Printer
I have a LexMark C752L. when i go to print first thing in the morning i get a 3/4" verticle stripe on the right hand side of the page. With each page i print this stripe gets less noticable until it...
Based on your description I would assume this has something to do with the Transfer belt, where in the cleaning blade of the belt is already worn or defective.
You may need to replace the printers transfer belt unit.
For further diagnosis and assistance, please contact Lexmark Technical Support.
Regards!
Sep 22, 2011 | Lexmark C752 Printer
Is there something I can clean on my HP Laserjet 2600n. I've done the recalibration and things that are built into the menu system. The colors appear faded, especially red. There's an echo-type of...
Using the REPORTS MENU print the "color supplies status". Make sure everything is good.
Select SYSTEM SETUP. Select PRINT QUALITY. Select CALIBRATE COLOR. Select CALIBRATE NOW.
Check the Transfer Belt(ETB) which is inside the front door. Make sure that it is free of your "racing stripes".
You can use HP TOOLBOX to troubleshoot.
You are using HP cartridges???
Dec 12, 2010 | HP Color LaserJet 2600n Printer
Hp color laserjet black print fades to the bottom of the page.
dirty scanner.open the printer back cover.remove the scanner assembly clean it ,do the color calibration.u should be fine.
Amuna1
Jun 30, 2010 | HP Color LaserJet 2600n Printer
Hp 2600n printer printing light on the left side of the page
clean the scanner & calibrate the printer thre times ur problem will be resolved
Jun 03, 2010 | HP Color LaserJet 2600n Printer
Color ink on transfer belt
I posted the problem on 4/6/09 about my HP Laserjet 2600n with the black line from top to bottom on all pages. The issues ended up being with one of the toner cartridges. I replaced them all - and the line went away! I will need to go back now and find out which one it was, and then I'll toss that one, and I will keep / reuse the others.
Apr 01, 2009 | HP Color LaserJet 2600n Printer
Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printing Problem!
franko21:
It sounds like you are having an issue with your fusing assembly. Here's the check you need. Measure the distance from the original print on the page and the exact spot where the repeat ghosting (same spot) appears on the page again. Here's the distances that identify the part having an issue. My guess and experience with this printer says it's probably fuser. Seen a lot of 2600n printers with image ghost problems and almost all are fuser related.
2.22" or 56.6mm = Fuser Upper Film
2.47" or 62.8mm = Fuser Lower Roller (Usually Backside)
2.97" or 75.4mm = Toner Cartridge - Drum (Usually One Color)
0.97" or 24.7mm = Toner Cartridge - Developer Roller
1.05" or 26.7mm = Toner Cartridge - Primary Charge Roller
2.15" or 54.5mm = ETB - Transfer Belt (Big Belt on Door)
If it should be the Fuser or Transfer Belt, consider not replacing the part as the minimum cost for either (part only) is $105.00 before shipping. The better alternative is to jump on Ebay and buy a HP refurb or new machine MINUS the supplies. They come with the Transfer belt and fuser. They are cheaper for the full machine than the replacement part. They average about $65.00 thru $90.00 landed.
Hope that helps you. If so, hit me with a FIXYA.
Aug 25, 2008 | HP Color LaserJet 2600n Printer
HP 2600N dark gray line down the left side
Maybe your transfer belt is damaged. If u have an spare belt replace it for a test. Answer me if it dont work. Maybe i can get an support manual for u. I work in a HP partner company.
Good luck
Dec 15, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
346 people viewed this question
Ben Johnson
