Question about Apple iPod nano
My I pod will not charge or connect to my computer
My ipod run out of battery and when I connected the ipod the ipod will not charge when i disconnect it it will said connect to power then when I connect the ipod it will not charge and will not connect to the computer the computer say's that the computer found a strange usb but the ipod will work like if it had nothing but will not connect and charge but works fine its just that it will not connect and charge. can anyone help me fix my problem.
  • bonis1 Jan 29, 2009
    my ipod wont charge or connect to my computer
  • 3 Answers
Try a hard reset
hold center button and upper button at same time until apple logo shows, then let go. Maybe that will help
Posted on Jan 29, 2009
My I pod stopped working
How old is the battery ipod batteries can only be recharged a certain ammount of times before they need replacing
If an iPod appears not to turn on, check the hold switch on the device.
If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
If that is determined not to be the problem, the battery's charge should be checked. When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds.
If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
If no battery icon appears when trying to turn on the device, try resetting the iPod.
Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset procedure tried again.
hope this helps
Aug 19, 2012 | Apple MA146LL/A 5th Gen Video iPod 30GB -...
My Ipod only works when connected to computer, once i disconnect immediately turns off. whats could be the problem?
When the IPod is connected to the computer, it also charges the battery.
Leave the IPod connected to the computer for several hours so it can charge the IPod's battery.
When you disconnect the IPod after several hours and it still turns off, then the IPod's battery is dead and needs to be replaced.
Sep 19, 2010 | Apple iPod nano 3rd Generation
My kid was playing with it and now i cant unlock my screen
Hello :
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.
good luck .
please rate !
Mar 30, 2010 | Apple iPod nano 3rd Generation
I cant get the lock of my i pod
Connect your iPod to your computer and open iTunes. When you disconnect iPod from the computer, it should no longer be locked. This will only work with the computer that you first used when you first connected your iPod and ran iTunes.
If this doesn't work, you can restore your iPod to factory settings, which has no lock code. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
If you want to to do this, connect your iPod to your computer and run iTunes. Click on your iPod on the left side of iTunes, then click on the "Restore" button on the right. After it's been restored, click on the "Sync" button to copy all your music and videos back onto your iPod.
Feb 11, 2010 | Apple iPod nano
I pod wont turn on
It's not a bad battery. There's a loose connection or disconnected wire inside that needs to be re-soldered.
Aug 07, 2009 | Apple iPod nano MP3 Player
Battery depletes over night after fully charged with no use
This is because the cable that connects new battery to iPod is either damaged, or has come loose...
Take it back to whoever performed the replacement... Or, I can walk you through the repair myself, but you will need a VERY thin flat-head screwdriver (like the kind in glasses repair kits).
P.S I GUARANTEE this is your solution... I'd stake my iPod on it.
Apr 23, 2009 | Apple iPod MP3 Player
Not able to switch off the word chARGING
I had the same problem
u must leave it open and wait for the battery to get discharged.
Then the i pod will come ti its senses
Jun 27, 2008 | Apple iPod nano
I Pod 4 Gb
Just charge the battery until the indicator says the battery is full.
well since its been connected for more than enought, disconnect it, you can also try reseting the ipod incase it has frozen
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
May 18, 2008 | Apple iPod nano
80gb black ipod video
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
If you need more assistance let me know. I'm here to help.
Nov 30, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
100 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
