Question about Avaya 700340193 Corded Phone
AUTOMATED ANSWERING AFTER 2 RINGS
CAN'T MAKE IT CHANGE AFTER MAKING SEVERAL ADJUSTMENTS.
Feature 00
left intercom
left intercom
#506
If early release:
1 for immediate
2 for delayed
or it will ask for line number, then enter the amount of rings
When done, feature 00
Posted on Feb 12, 2009
How do I change the number or rings on my vtech cs6619-2
The CS6619-2 isn't an answering machine. It will continue to ring until someone or something picks up, or the caller hangs up.
To change the number of rings before your answering machine picks up, please consult the documentation for your answering machine.
Dec 05, 2012 | Vtech DECT 6.0 Digital Cordless Phone
I have an officejet 6500 all in one printer and I am setting up the fax section. It sends and recieve OK but my answering machine is picking up before the fax machine. How can I change that around so the...
You need to check the setup ..
The telephone line which is coming from out should be connected to the line 1 of the printer and Telephone answering machine should be connected to Line 2 .
2. You also need to check that after how many rings the Telephone answering machine answers the call you have to keep the "Rings to answer" 2 less than that of Telephone answering machine.
Lets assume that your Telephone Answering Machine answers the call after 4 rings then keep the rings to answer in All in One to 2
How to set Rings to Answer
1. Press the Setup button on the Front panel of the printer
2. Scroll Down and go to Basic Fax Setup - Select it
3. Scroll down and got to - Rings to Answer - Select it
4. Set the Rings here and then try Fax
it will fix the problem :)
Feb 26, 2011 | HP Officejet 6500 Wireless All-in-One...
Our digital answering feature now picks up after 2 rings, it has always rang 4 times. Is there a way to adjust back to 4 rings?
click menu 3 times. click either repeat/rew or skip/ff to set to either 2 for 2 rings or 4 for 4 rings or 6 for 6 rings or h5 for toll saver THEN press set/ringer to save your change. Answering machine will answer after 4 rings if you wanted the 4 & saved by pressing set/ringer. Thats all there is to it.
Mar 29, 2010 | Uniden Cordless Phone exai398i
My uniden phone rings and goes to answering machine in 2 rings
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Jul 24, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Alcatel 630 telephone
The phone rings once or twice but then it stops ringing despite the fact that there is still a ringing tone on the caller's phone.
Furthermore, the answering machine does not take the message as it does not click into answering mode. Any messages are left on the automated voice mail.
Thanks
Aug 28, 2008 | Alcatel Lands Phones
Hangs up after 2 seconds into recording message
SETTING THE RINGS TO ANSWER
This setting allows you to select the number of rings before the answering system answers a call.
At idle status, hold down the volume "UP" button over two seconds to enter the ring times setting of answering. The answering system announces, "ring time two" (the default is 2).
To change the rings to answer, press and release the "PREVIOUS" button (<<) or the "NEXT" button (>>) and the answering system announces a number such as "2, 1, toll save, 9...” OR "2, 3, 4...", if you select the toll save and the digit LED light shows a “γ”, the answering system announces “toll save”.
After choosing a number, press the “PLAY/STOP” button one time to store the rings to answer, and the answering system confirms the setting and returns to the idle status.
NOTE: when the machine fails to operate properly, just unplug the power for 10 seconds, and redo the settings.
Aug 03, 2008 | Emerson Em1200 Answering Machine
How can I change the Rings to Answer setting to one ring?
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1.
Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
Get manual at http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Jul 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Answering machine atarts working after 2 rings only
Press the 'Change' button
Press the 'Setup' button until you hear the voice say "Number of rings"
Then use the "Skip" and "Repeat" buttons to change the number.
Press the "Change" button to finish.
Jun 11, 2007 | AT&T 9350 Cordless Phone
Avaya 700340193 Corded Phone Logo
79 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
