Question about Toshiba e-Studio 161 Copier Copier
Error code H2 on screen
Hi i have a toshiba e studio 161 and we had a power cut for about 1/2 hour since then it wont work and displays H 2 on the screen, before the power cut it was working fine, thanks, paul.
  • Anonymous Jan 29, 2009
    there is no hash key and we dont know what the interrupt key is x
  • Anonymous Mar 20, 2014
    error h2
    President:
  • Toshiba Master
  • 990 Answers
Hello sir; H2 code require reset procedure as follow;
1, press "#", "interupt", "c", "interupt" these 4 keys.
2, enter 14 then press start.
3, turn power off and back on .
Posted on Jan 28, 2009
    Problem Solver:
  • 3 Answers
Press alternatively Contrast mode Key(Auto/Text/Photo) and cancel "c" Key to enter service mode, while entering into service mode everything goes off, then press 14 and print(start) then turn the power off and back on
Posted on Feb 06, 2009
How to reset Toshiba e-Studio 161 Copier Copier with "error code H4"
Step 1:-
Press
"C" key AUTO/TEXT/PHOTO key
"C" key AUTO/TEXT/PHOTO Key
(Note:Perform the first two key strokes quickly )
Machine display should stop blinking
Now press 14 and press start button.
Switch off and on to check
Feb 27, 2016 | Toshiba Office Equipment & Supplies
Estudio 161 4h error code
h4 low heat from heater unit do the following [c key]-[auto/text/photo key]-[c key]-[auto/text/photo key] machine will go dead key in 14 press print machine will cycle if the error code returns you will have to replace thermistors and thermofuse
Mar 19, 2011 | Toshiba E-Studio 161 Copier
I have H2 flashing on my Toshiba e-studio 161 copier
h2 error is the fuser unit is faulty check and replace heater lamp thermo fuse and thermistor
Mar 07, 2011 | Toshiba e-Studio 161 Copier Copier
TOSHIBA E-STUDIO 161 error code show mw H and 4
How are you this is jack my id jack_pak@hotmail.com
your copier toshiba 161 show H...4
Dear, Follow the procedure.... press C(CLEAR) BUTON+ PHOTO BUTON+C BUTON+PHOTO BUTON..... Your copier enter special mode
Then you press 14 and start key.... copier ...ok
PLEASE VOTE ME
Thanks,
Best Regards,
Aug 31, 2010 | Toshiba e-Studio 161 Copier Copier
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
Toshiba e-studio 161 error code H2?What reset problems?
does not solve these problems H2? substituted for the other thermistors, but still nothing same error ... The whole problem of the scheme not remove the plug from the power supply and printer cable recorded the error, which now does not solve ... help ??????
Jan 12, 2010 | Toshiba e-Studio 161 Copier Copier
Can't print or copy with my toshiba e studio 161
H2 indicates thermistor open.
U can enter simulation mode and input "14" to clear the message.
If happen again, u need to check following:
Thermistor
Control PWB
Fusing section connector disconnection
The fusing unit is not installed.
Perform the following procedure to enter the simulation mode.
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
Jan 15, 2009 | Toshiba e-Studio 161 Copier Copier
Error code L6-10
sir, I ma indian & I have a tosiba estudio 161 I have problem diaplay in on display screen when i switch on the start so display show screen ---
Jul 02, 2008 | Toshiba e-Studio 161 Copier Copier
Toshiba e-Studio 161 Copier Copier Logo
479 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
